It is currently Tue Jun 16, 2026 9:34 pm
PostPosted: Thu Oct 09, 2008 1:10 pm
I have three swivel cam cleats on my '83 H16 (two on the jib sheet and one on the main sheet traveler). Recently an internal spring on one of the jib cleats broke. I could not find a replacement spring and had to buy a whole used cam cleat for $25. Those have a left and a right spring. I used the left one to replace the broken one, but a couple of days ago another one broke, this time on the main sheet traveler, and again a left. Does anyone know where I can get the replacement springs only - they should cost pennies?[/img]
PostPosted: Thu Oct 09, 2008 1:59 pm
Depends on the make of the cleats.
Could be SeaWay, Harken, Ronstan or several other makes.
Photo of the cleats and or spring could help identify it.
PostPosted: Thu Oct 09, 2008 6:00 pm
Matt,
It is the Harken Cammatic Cleat shown in the Hobie catalog under 50009 with aluminum jaws H150.
Thanks.
PostPosted: Thu Oct 09, 2008 6:23 pm
The spring is Harken part number HSB56. They're a $1.95/ea. There's not a right and left. Just flip the spring.
PostPosted: Thu Oct 09, 2008 6:59 pm
Perhaps I misidentified the spring - it clearly is unflippable - see photo, hopefully....
http://www.flickr.com/photos/31269219@N02/2928418338/
PostPosted: Thu Oct 09, 2008 8:01 pm
weltwindsand wrote:
Matt,
Thanks.
No, you misidentified the cleat.
That's from an old Seaway or Ronstan, probably Seaway.
Do youself a big favor and replace the whole cleat with the Harken version. It works much better.
PostPosted: Thu Oct 09, 2008 8:23 pm
I have been replacing a lot of things. It is hard to keep up. I have not had issues with the cam cleats, other than the broken springs.
To help with ID, here is a picture of the whole swivel cam cleat. Thank you again.
http://www.flickr.com/photos/31269219@N02/2927719431/
PostPosted: Fri Oct 10, 2008 5:32 am
Any specifics behind the new boats having Ronstan cleats?
I've had broken springs in Harken cleats, with frozen screws as well, my experiences have been frustrating. :?
Sheet In...Max Out
www.fleet297.org
PostPosted: Fri Oct 10, 2008 8:49 am
The cleat is SeaWay. We don't have replacement springs here... maybe at a dealer?
We went to Ronstan when the jib cars started coming from Australia. Hobie Australasia designed the plate and car, so they supply us.
PostPosted: Fri Oct 10, 2008 8:53 am
Thank you, Matt!
I guess I will have to replace the cleats after all.
PostPosted: Sat Oct 11, 2008 5:45 pm
Those springs for the Seaway cleats are getting hard to get! Some dealers have old stock, but go on and replace with the Harkens or Ronstan- you'll be glad you did!
PostPosted: Mon Oct 27, 2008 6:40 pm
I have the same issue on my '84 H16.
To replace the whole cleat what do I need to order?
Can I replace just the cams on the same swivel?
Is the old swivel riveted to the crossbar?
Thanks for your help.
Kent
PostPosted: Tue Oct 28, 2008 6:10 am
The swivel is screwed into a base plate with 3 screws.
However, the seaway cams have two posts that come up off of the swivel plate. The Ronstan cams won't just fit on those.
I'm in the same situation. I've got a set of Ronstan cams, but they won't fit on the old seaway plate. I see that you can buy a new plate that comes with the cams. Is it possible to buy just the swivel plate without the cams?
1984 H16 - #80541
