It is currently Wed May 06, 2026 4:28 am
 Post subject: Hull Repair
PostPosted: Fri Apr 08, 2005 2:05 pm
I recently was given a 14 Hobie by a neighbor (long story). The biggest thing that needs to worked on is two holes in the outer hull. One hole is about an inch, the other is a little smaller. Any suggestions on what to use to patch them?
PostPosted: Fri Apr 08, 2005 10:51 pm
There is alot of products to fix your holes. I would do searches on fiberglass repair and read up on what will work best for you. try here for starters
http://www.jamestowndistributors.com/de ... repair.htm
If there are access ports it may help, I would also check the decks for soft spots. " Delaminated parts of the fiberglass " ,and flip the boat over and put a bead of waterproff epoxy around the edge where the fiberglass are sandwiched together.
Todd
PostPosted: Mon Apr 25, 2005 10:57 am
Check out the repairs we made to my friend's Sunfish for ideas:
http://www.JaimeZX.com/Boating
Warm regards,
Jim
