It is currently Tue Jun 16, 2026 6:40 pm
Post new topic Reply to topic  [ 167 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 12  Next
PostPosted: Fri Jan 16, 2009 12:40 pm
JollyGreen,
It's my experience (very limited that it is), that Chrisj is correct.
The boat wants to be carried & loaded the right way up, and will fight you to be carried and loaded that way.
I have Thule square bars on a roof rail, and the xbars clear the roof when turning the boat over ready for strapping down.
Ger.
PostPosted: Fri Jan 16, 2009 1:14 pm
What Ger said :)
PostPosted: Sat Jan 17, 2009 3:56 am
I saw an AI on a set of roof bars on a small 4wd in Lake Tyers Beach this afternoon that looked to have been loaded with ama's & aka's still intact.
Must have been an awkward lift. Pity I didn't have time to stop and knock on the blokes door and find out if there's yet another AI in the Lakes area or whether they were visiting from out of town.
Dave
A Hobie Sport and 2 Hobie Adventure Island's - Papaya & Hibiscus - I couldn't make up my mind so like I usually end up doing with lures I bought both and hid the credit card statement :)
PostPosted: Sun Jan 18, 2009 7:04 pm
Pirate wrote:
The problem of carrying the Adventure Island on the roof racks is two fold. One getting it up on the racks in the first place easily and safely, and two how to carry and secure it.
I solved the problem in getting it up by purchasing a Rock 'n Roll bar for my Thule sports bars but found like Chrisj posted earlier, it is a difficult job to get the hull up in the already inverted state. The boat wants to turn over and if you can manage that there is the real concern of damaging either the car or the roof bars with the aka braces. The easier method was to lift it up right way up then invert it up there. This in itself led to damaging the rubbers in the bars as I re-positioned the inverted hull on the racks for balance. Not a happy camper.
This led me to lifting the boat right way up and tieing it down in that state with Hobie straps. Great way to do it except that the pressure from the tight straps forced the bottom to distort where it came in contact with the roof bars. I carried it around like this a couple of times but did not like the possible consequences of hull distortion or worse over an extended period.
I looked at the dedicated kyak 'clamps' but I don't think they are really suitable for the AI hull, and restricts the racks being used for carrying other stuff.
Now my solution which I have trialled for a couple of weeks and several trips of several kilometers is to built two soft 'Pirate Pillows' that go between the hull and the racks. These both support the hull across all its full width and take the pressure when the straps are pulled down tight without any distortion of the hull. They also provide grip between hull and racks and I have only needed to secure the hull with the hobie straps and not secured it front or rear so far. I may tie a front bow strap down to the car for the 200 mile trip to Mallacoota on the weekend, just to be safe.
Both ' pirate pillows' are made out of the insulation foam tubing that is commonly used in the air conditioning industry. It is reasonably inexpensive easily obtainable. The foam is very durable in this application and will not hold a memory and will take its original shape after a short time of a load being taken off it. The foam tubing I used is approx. 110mm in diameter and 30mm in section and slit down its length so it will fit over each rack. Each 'pirate pillow is 530mm in length with additional width at the ends with an additional 100 mm of the foam tubing super glued to the one below effectively giving it a thickness of 60mm there. The superglue loves this stuff and is instantly glued on contact. Now this arrangement with 60mm thickness on the ends for a 100mm then 30mm in the centre is just perfect for the shape of the bottom of the hull at the areas where the roof racks will be.
The above is a diagram shows its shape. Here are some photos of it on my car. You need to pull down tight on them to compress the foam after which the hull will not move around at all.
The above shows the pirate pillows immediately after the boat has been removed. The foam very quickly goes back to original shape.
You can even use these very same pirate pillows on your storage racks like I do.
I strap the two amas together face down on the same racks beside the hull using two more Hobie straps for which there is plenty of room
So far I am very happy with this inexpensive fix, approx $40 total, which allows me the freedom to carry the boat upright allowing me to leave the seat and some gear in the boat without salt water dripping all over the car on the way home from a great day out Hobie Adventure Islanding...Pirate :wink:
Just thought I would repeat this item as the pirate pillows are a real winner. No need to ever go to the trouble and drama of inverting the boat up on the racks ever again and possibly damage the rubber rack inserts when you can just build some pirate pillows and travel with her right way up. Just back from Mallacoota, some 300 ks away from Bairnsdale. On the way down I put a bow line attached to the car grill just to be sure, with no movement at all at 100kph. On the way back, removed the front line, again no movement at all. The boat travels like a dream without front or back lines, no hull distortion when pulling the straps down tight, and soooooo easy to load. Also not nearly as much salt water gets on the car as dont have dripping seat etc. which you can leave in the boat. An all round fantastic success and I highly recommend car toppers make themselves a set of two. Mickey even suggested using them as real pillow on our camping trip as they would work for that purpose too... Pirate :wink:
PostPosted: Sun Jan 18, 2009 7:25 pm
In no way detracting from the Pirate pillows Pirate, but the real test of boat security has to be in conditions of rapid deceleration - slamming on the brakes or a collision. I dunno if attaching a line to the grill would be much help under those circumstances anyway. Can't argue about whether inverted or upright is better - we seem to oscillate 180 degrees out of phase on that one :)
Chris
PostPosted: Sun Jan 18, 2009 10:53 pm
Chris
Hi Chris. You misunderstand what I said. I now DON'T use any forward line at all. The boat will always be restrained by the straps. If the boat shifts at all forward, then the aka braces will stop it in its tracks as the rear strap is positioned forward of the brace. No need for either for or aft lines as in a collision a stern line will of minimal benefit....Pirate
PostPosted: Wed Jan 21, 2009 1:03 am
<img src="http://photos-h.ll.facebook.com/photos-ll-snc1/v2053/133/36/729788944/n729788944_1244095_5314.jpg">
Here is the bar/brace I built for assisting in car topping the AI hull when I'm by myself. The rack I have doesn't allow the use of those slide out bars for side loading, so I had to build my own, and it was cheaper too! I think all the PVC parts came to under $20. I've loaded and unloaded several times now with no issues and the brace breaks down into 4 pieces that easily fit into the trunk! Also, it's easier to load the hull on the brace with the seat up (normal kayaking position), and get it on top of the car in that position. Then once it's on the roof, flip it over into "inverted" (the seat facing down) position and strap it down.
Jeremy
PostPosted: Wed Jan 21, 2009 3:11 am
Jeremy,
I like the sound of this, but I can't open the picture. It's probably me, but has it been attached in a different format or something?
Ger.
PostPosted: Wed Jan 21, 2009 3:40 am
Ger wrote:
Jeremy,
Ger.
I don't see the picture also JG....Pirate
PostPosted: Wed Jan 21, 2009 4:33 am
Pirate wrote:
Ger wrote:
Jeremy,
Ger.
Me niether
Mickey
PostPosted: Wed Jan 21, 2009 9:58 am
Alright, check it now, I put it on facebook and I'm trying to use that a link to that. Hobie should really add a picture upload feature to their forum!
Jeremy
PostPosted: Wed Jan 21, 2009 12:10 pm
Jeremy
I am glad they don't Jeremy as it would bog down the forum down and slow it up....Pirate
PostPosted: Wed Jan 21, 2009 12:47 pm
Pretty nifty JollyGreen :)
PostPosted: Wed Jan 21, 2009 1:38 pm
Great piece of lateral thinking there Jeremy. Supported right through to the ground does make sense. The commercial Rack & Roll system I bought relies totally on the integrity of the roof-rack bar and the leverage forces must be quite substantial whilst the hull is unsupported out on the R&R bar. My Thule sports bars copes easily though and it is a quick and simple solution, but yours seems equally as good.....Pirate
PostPosted: Wed Jan 21, 2009 2:52 pm
Jeremy
This is a standard design message forum, from phpbb, and you have enough space taken up with posts, to not want pictures as well. I say that as a forum owner.
Its a good idea, and I could well have done something similar, but I made up a lift at the bow end. I needed to clear the saddles, is why.
Geoff.
