It is currently Mon Aug 03, 2026 1:04 pm
 Post subject: Siren's song?
PostPosted: Wed Feb 11, 2009 11:49 am
Under certain speed and conditions my boat starts to whine or sing. I presume this to be caused by the asymmetric hulls or perhaps rudder vibration. Three questions: 1. What causes this noise? 2. Is it bad? 3. If so, should I try to fix it?
When I used to crew for guys back in the seventies they seemed to think singing hulls was a good thing... like they were sailing on the edge or something. I think the sport was so new back then that they really didn't know WTF.
PostPosted: Wed Feb 11, 2009 1:19 pm
Its the rudders...
From the support pages:
PostPosted: Wed Feb 11, 2009 6:41 pm
Actually I used to like to singing, it kind of added to the sensation of speed. I've never got my getaway to sing like that.
PostPosted: Thu Feb 12, 2009 6:56 am
mmiller wrote:
Its the rudders...
Bummer. My rudders were badly yellowed so I just finished painting them. Thanks for the explanation. I'll just tell folks that I'm sailing on the edge! :lol:
PostPosted: Thu Feb 12, 2009 9:41 am
Not all trailing edges are the same. The Tiger & Fox blades that I've worked on are way too thin, and can chip just like a potatoe chip. Others are way too wide which can cause severe humm & vibration. We're putting together another article for the HOTLINE which will cover these issues.
PostPosted: Thu Feb 12, 2009 10:39 am
What's the HOTLINE? How do I get it?
PostPosted: Thu Feb 12, 2009 11:01 am
On-line version is here: http://www.hobiecat.com/hobieclass/
To get a hard copy, you need to join the Hobie Class Assoc. of North America, here: https://www.hcanamembers.com/
PostPosted: Wed Feb 18, 2009 12:21 pm
I like the humming. :) Usually it happens when you are going at a pretty good pace or just about to lift a hull. Didn't somebody have a story about dolphins being attracted to the hum?
PostPosted: Wed Feb 18, 2009 8:20 pm
Not that i have seen but it sure makes my dog bark lol
 Post subject: HUUUUUUMMMMMMM!
PostPosted: Wed Feb 25, 2009 3:35 pm
Had to jump in here. I did the scissors thing and used a straight edge to check for hollows. Looked pretty good. Out on the water at about 10 knots they scream even louder. Back to the sanding board. This time I used a belt sander with 90 grit and carefully took the trailing edge down to 0.10 of and inch and squared off the back edge. Still screams. I've given up.
PostPosted: Wed Feb 25, 2009 5:05 pm
Don't give up...I've sent Matt the info for the HOTLINE article on rudder repair. Be patient.
PostPosted: Thu Feb 26, 2009 6:54 am
After Matt's suggestion I went back and took a gun sight look at the trailing edges of my rudders. I couldn't see anything that looked like a flare, bulge or even the slightest distortion on either rudder. If that is what is causing my hum it is very subtle indeed. I'm more inclined to believe it is toe-in, vibration or some other adjustment. I am going to tighten my upper castings with additional shims and will probably try the cellophane, silicone caulk trick to the lower casting.
PostPosted: Thu Feb 26, 2009 10:24 am
Some rudder materials seem to hummm more than others. I would bet you have Lexan blades. These do not have a smooth (shiny) surface. They have a glass fiber / swirl look. The harder material made it more difficult to remove the humm.
It is most definitely the foil shape causing the humm... not rake or toe in.
PostPosted: Thu Feb 26, 2009 5:12 pm
Hey Sunvista, send me a private email address for you so I can send you some photos of rudder work. [email protected]
PostPosted: Fri Feb 27, 2009 6:32 am
Rick...sent as requested. Thanks
