It is currently Tue Aug 04, 2026 3:08 pm
 Post subject: Marine Goop On Hobies
PostPosted: Tue Feb 24, 2009 6:53 pm
I googled the material of HOBIES and found that they are POLYETHYLENE, the funny part is the FF install Kit came with Marine Goop but, if you read the back it says it is not recommended on POLYETHYLENE?......Steve
I just mounted the transducer so it is a little to late! What does anyone think?
PostPosted: Wed Feb 25, 2009 9:57 am
The transducer does not require much of a bond to the inner hull. The Goop is mostly to create a consistant (no air or bubbles) material to shoot the signal through.
Sanding the hull first helps create a better "mechanical" bond.
PostPosted: Thu Feb 26, 2009 9:30 pm
Hobie Team Member
We use Goop all the time to mount the foam block the transducer fits in. We generally don't Goop the transducer to the kayak.
We cut the foam block on angle, tighter on the top wider against the hull fits tightly, all you do is add a little water works great.
KFA-NY
Founding Member
