It is currently Wed Aug 05, 2026 2:24 pm
PostPosted: Sun Mar 15, 2009 11:55 am
I need two new hinges for the cabin windows. The holes are not drilled standard and hobie doesn't have any parts listed forthe piano hinges?
Also what are the jam cleats for on top of the cabin?
PostPosted: Sun Mar 15, 2009 12:46 pm
You can find a parts diagram for the Hobie 21SC in the support area of our site: http://static.hobiecat.com/2010_archive/support/pdfs/21SCParts.pdf
I will review this post again on Monday when I head into the office.
The only cleat on top that is "factory" equipment is the jib furling line cleat.
PostPosted: Sun Mar 15, 2009 1:55 pm
Yup looked there. found a 36800081 and a 36800091 as the window assembly's but nothing is mentioned of the hinge. Must be part of the window?
PostPosted: Mon Mar 16, 2009 9:10 am
I looked at inventory today. No replacement hinge is available from Hobie. The hinge came as part of the window from a vendor. It was commonly refered to as Piano Hinge, so you should be able to find based on that description.
This quick Google search result looks like the stuff:
http://www.monroeengineering.com/hinges/pianoHinges.htm
PostPosted: Mon Mar 16, 2009 10:55 am
I've talked with a few companies. The guys you listed look best because they are not drilled yet.
Most Piano hinges will be drilled on 2" holes spacing. But hobies were drilled on 3 3/4" holes center to center. So i can't use the standard replacements.
PostPosted: Tue Mar 17, 2009 10:38 am
For anyone else looking the part number is
Our Part# Description Quantity Price Extended
CS24010672 1240 SS 1 1/16 X 72" HINGE 1 19.71 19.71
Order subtotal 19.71
 Post subject: What a Disaster!
PostPosted: Thu Mar 19, 2009 12:33 pm
SO i tried making my new hinges today. cut the blank stainless to length. clamped the old hinges to the new ones, marked, and drilled the new holes.
At first it seemed a little tight against one side, but it was still working. so i siliconed it all up. Bolted it down(two holes in the window didn't line up). And then as i tightened it it got further and further out of alignment to where it was impossible to close.
SO i unbolted everything and switched the hing to the other side(there was a slight offset in my stock hinges) That door fit well in the frame. but two of the window holes didn't line up and a third felt stripped. SO i tried drilling new holes to align better. first hole was drilled and piloted but i stil got a "crack" when i went to tighten it down, the second hole i guess the originals were drilled at an angle. Drill bit broke, glass chipped in the bottom edge. now three of the windows holes are unusable and the window is visibally pulling away from the hinge when resting in the open possition.
WHAT A DISASTER. My cat cabin was FLAWLESS prior to me attempting to redo these hinges!!! I feel like a pile of dog leftovers right now.... :oops:
PostPosted: Thu Mar 19, 2009 2:17 pm
That doesn't sound real fun at all.
We do have complete window replacements available still $140 each side.
PostPosted: Fri Mar 20, 2009 6:40 pm
Sounds like any one of my projects :roll:
Measure with a micrometer, mark it with chalk and cut it with an axe...
TC
PostPosted: Sat Mar 21, 2009 6:33 am
What were the original windows made of? Mine are wood.
Practice makes perfect, so be careful what you practice...
PostPosted: Sat Mar 21, 2009 11:38 am
Wood? Really?
The originals are smoked plexiglass.
PostPosted: Sat Mar 21, 2009 1:50 pm
Very dark smoke. I think they are virtually Opaque. wood is an interesting concept. I ended up jbwelding inside the cracks and clamping the widow overnight.
Looks to be holding so far but wait till some drunky needs to get there camera out of the hold and leans on it. LOL
