It is currently Sun Aug 02, 2026 3:37 am
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
PostPosted: Thu Apr 30, 2009 8:34 am
Hobiekc - how did you make the pictures show? I must be getting old and need my kids to help. wtf
PostPosted: Thu Apr 30, 2009 10:58 am
spesce, I don't know why your post doesn't show the images. Your original post appeared to be correct so I did a quote of your post and voila, images appeared. Maybe something to do with your user access? MMiller would have to explain.
PostPosted: Tue May 05, 2009 3:00 pm
It's a tramp bag used in the '86 and '87 Hogs Breath 1000. The '86 bags were yellow I'm assuming the '87 bags were blue. At some point I've seen these bags in a catalog some where. The center section held charts. One side section held the eperb and flares, that's what the pockets were for. The other section held food and gear. The bag was monted from side rail to side rail with two lines going underneath the tramp. The second year we chose to tie it to the center of the tramp going from front to back.
PostPosted: Tue May 05, 2009 4:34 pm
I did fit on the boat this past weekend. It does fit from side to side with straps going underneath tramp. The trampoline on the 21SE is center and front lacing and I did not know how this was going to fit. The front strap goes thru the front lacing and under the tramp and the rear strap goes thru a grommet on each side. Perfect fit and full width of the 21SE tramp, ie 8'. It also has a front middle strap to go around the mast base. It keeps all the extra lines from interfering the tramp.
I am still working out the bugs and have not had the boat on the water. I will take pictures when this happens!
