It is currently Mon Jun 22, 2026 9:33 pm
PostPosted: Thu May 14, 2009 10:57 am
Has anybody installed a Hobie Baby Bob float on a H-18 mast?
I know the baby bob was designed for the H-16, but I was wondering if anybody had fabricated a way to install it onto a H-18 mast.
I don't have a comp tip.
Thanks in advance.
PostPosted: Thu May 21, 2009 9:06 pm
Anybody?
PostPosted: Fri May 22, 2009 3:26 am
Check out the bracket idea shown on http://www.thebeachcats.com Technical Photo Gallery.
http://www.thebeachcats.com/index.php?module=pictures&g2_itemId=34617
The Baby-Bob and the Mama-Bob have the same mount-bracket on the float.
Without a comp tip this solution works great. I’ve had done this install when I first got my H-18. With the bolted on brackets, I can quickly remove the “Bob” from the mast by removing two attachment bolts and leave the angle brackets attached to the top of the mast.
I’ve gotten over the fear of tipping the H-18 and no longer use the Baby-Bob but the angle brackets are still attached to the top on my mast.
John Latimer
'79 Hobie18 - Magnum
Sail#4854
PostPosted: Fri May 22, 2009 9:13 pm
Yes, It goes on almost perfectly, with only a slight modification. My mast had a comp tip though.
Go ahead and order the baby bob, It will fit and it will float your mast indefinitely when your boat capsizes...I have it on my H20 now.
Wes
92 Miracle 20 + magnum wings
PostPosted: Thu Jun 11, 2009 3:27 pm
How do you do it on acomp tip? Stainless halyard hook?
MACOTAC
PostPosted: Thu Jul 02, 2009 8:03 pm
I just finished installing a baby bob to my H18. I used 1/8" thickness aluminum tubing that was 3 1/4" x 1 1/2" x 3/4". It wasn't quite wide enough but it should do just fine.
I had to grind down the little bump on top of the mast head and also cut away a bit of the aluminum angle thats in front of the uphaul sheave.
Pete
1982 18' Hobie
Users browsing this forum: Google [Bot] and 1 guest
