It is currently Fri Jun 12, 2026 12:29 pm
PostPosted: Mon Jun 13, 2005 7:00 am
This is kinda a stupid question, but here goes. I just bought my first cat, an '82 H16. What is a comptip mast, how can I tell if I have one, and what's the advantage? Also, I'm a little interested to find out how to right the thig when I crash it (because I'm sure I will...). TIA!!
'68 O'Day Widgeon
'82 Hobie 16
'82 Siren 17
'81 Catalina 22
PostPosted: Mon Jun 13, 2005 11:41 am
The top 1/3 of CompTip masts are fiberglass. This is due to morons raising the mast or sailing into power lines and then suing Hobie. If you have one, there is a very small performance hit. Technically if you're into class racing you must have one.
Lots of posts on righting in here; just do a search. :)
Warm regards,
Jim
PostPosted: Mon Jun 13, 2005 2:19 pm
Not sure about the performance hit... I think they might be a US feature (not sure) They add weight to the mast top (yes sounds wrong that a section of plastic would make it weigh more - but it is a fact). This make the righting more difficult. They mess with the bending curve of the mast. They age fast under UV light - than you have really interesting bending characteristics.
They might perform better under strong winds and in gusty situations by spilling some air due to mast twist / lee way bend.
Righting the hobie is a combo of technique and equipment. Do a search on the topic. You will find plenty of info.
Patrick
PostPosted: Tue Jun 14, 2005 6:05 am
The performance question all aluminium masts x comptip masts is actually a hot question here in Brazil. The class rules specify all alumium masts here in Brazil, but some american boats have appeared here with comptip masts. I had the chance to sail both, and from my experience I can tell that the comptip masts is really easier to sail than the all aluminium mast, specially in strong winds, and it goes upwind better also. On light winds however I think the all aluminium mast will be faster (more power).
Best Regards
Tomas
PostPosted: Tue Jun 14, 2005 10:01 am
Thanks for the replies guys. I'll search for the righting technique. I was really in the dark on the mast thing. I think I'll stick with my aluminum mast.
'68 O'Day Widgeon
'82 Hobie 16
'82 Siren 17
'81 Catalina 22
PostPosted: Wed Jun 15, 2005 6:39 am
Two words: lightning protection.
I think that our Fleet 86 started falling apart when we questioned the need for a plastic tip and all rope halyard due to the negligence of someone who probably should have been given a Darwin Award. Our biggest concern on long narrow Finger Lakes was the sudden appearance of T-storms from the West or East that we could not predict because of the surrounding hills.
There is a "cone of protection" that forms around your highest conductive point I can't remember the formula, but the diameter of the base of the cone is roughly 1/3 of the height of the highest conductive point. In other words, with an all aluminum mast enhanced in conductive nature by a metal halyard on a H16 you have an area roughly protecting the tramp. Obviously, when you replace the top 1/3 of the mast with plastic, you lose 1/3 of the cone. I guess you could huddle around the mast, but it gets hard to sail in an approaching storm in that position while you are trying to get to shore - the safest place to be :wink:
I didn't change. I think will find very few boats in this area who did.
Sail on and enjoy it. I agree with the info on performance, (good one H16Brazil) but the usual wind favors the all metal mast. 8)
The fact that this windy world is largely covered in water obviously means that man was meant to sail.
