It is currently Sun Aug 02, 2026 4:26 am
 Post subject: Jib Downhaul Block
PostPosted: Thu Jun 23, 2005 1:42 pm
Does anyone know of a good replacement block from the jib downhaul block (Hobie 16). Mine is cracking. Maybe Harken makes something I could use (size/part #)? Thanks!!!
PostPosted: Fri Jun 24, 2005 5:04 am
if you mean the ones that are hanging on the jib clew plate, I use Harken H224 micro single block on my boat, they work great and are small enough.
Regards
Tomas
PostPosted: Fri Jun 24, 2005 10:07 am
Jib halyard - downhaul block #11070000
PostPosted: Fri Jun 24, 2005 6:36 pm
Thanks, I am trying to replace the down haul block that is used to tighten the jib wire. The Block is located near the base of the mast and the line is secured to a cleat on the mast.
 Post subject: Re: Jib Downhaul Block
PostPosted: Tue Aug 02, 2005 5:55 pm
http://static.hobiecat.com/2010_archive/support/pdfs/partguides.pdf pg 56 part# 20710000, 4 rivets #8010181
think you have to replace the entire block
