It is currently Tue Oct 21, 2025 5:49 am
Post new topic Reply to topic  [ 48 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Tue Jun 30, 2009 8:46 am
The manual seems to indicate that, but the trailer that Hobie sells and the cradles they sell are obviously for cockpit up usage. What is the deal-io?
PostPosted: Tue Jun 30, 2009 8:48 am
yes - this is correct. If you don't use the cradle set, the only way to transport it is disassembled up-side-down. The deck area is the stiffest, if you just had it sitting upright on a couple of cross bars - you are guaranteed to dent/damage the bottom.
PostPosted: Tue Jun 30, 2009 9:48 am
Hi, newb to the boards myself... kayaker and potential AI purchaser. I have a relevant question:
Would J-Cradles be a viable alternative to transporting deck-down on padded crossbars? Kind of like this-
http://www.backcountryracks.com/sportra ... -rack.html
Thanks!
=Timm
PostPosted: Tue Jun 30, 2009 9:53 am
Those work too - maybe not so good for an Island though - its best on a trailer with cradles- but if you 'must' car-top, of course you'll be taking the boat apart - so any kayak rack system will do the same thing, support the boat in some way or another - any of the rack companies can help with options, there is nothing unique about Hobie SOT kayaks to any other brand. So seek the expertise of the rack names (Yakima or Thule)
PostPosted: Tue Jun 30, 2009 10:22 am
Okay, thanks. I am indeed forced to cartop, as I am hauling my kayaks around on top of a Mini. So far, I've travelled quite some distance with two sea kayaks (15' and 17') without issue. Haven't topped a SOT yet, so I have some (light) concerns.
PostPosted: Tue Jun 30, 2009 4:25 pm
Kayak saddles that are available from most roof rack manufacturers also work well. It's easy to slide the kayak right way up straight onto the saddles and you don't have the hassle of turning it upside down when on the roof.
PostPosted: Wed Jul 01, 2009 12:27 am
:D :D :D Then there is the very best option of Pirate's Pillows which can be made inexpensively and will do equally a good job. My AI has been sitting on them upright now for 9 months with no distortion of the hull. I have two sets. One for the garage racks where it spends most of its time, and another for the car racks. :D :D :D Pirate
PostPosted: Wed Jul 01, 2009 4:47 pm
Uhh.. I'm almost afraid to ask what a Pirate Pillow is.
PostPosted: Wed Jul 01, 2009 7:31 pm
Sometimes a dacron filled stuffed parrot. Very comfy so long as the beak doesn't stick you in the back of the head.... :)
Or it can mean this (toward the end of the page)-
http://www.hobiecat.com/community/viewtopic.php?f=44&t=11367&hilit=pillow&start=45
Not sure if the photos are still there. Quite often then get blocked from here at work. So I can't see them right now.
PostPosted: Thu Jul 02, 2009 12:35 am
I've done both. Upside down better, no hull deflection. I once left my rig upright on the truck and strapped down all day while working, luckily the bend came out. Now only cockpit down for me.
Aloha ka'kou
PostPosted: Thu Jul 02, 2009 1:22 am
Mine is a different tale. Strapped down right way up on top of the 'Pirate Pillows' with no distortion what-so-ever, and spends its life on a set on 'pillowed' racks with no problems. Must be the Pirate Dacron. :D :D Originally tried 'wrong way up' but it difficult to get it up and over and the aka braces were very unforgiving on the car roof.....Pirate
PostPosted: Thu Jul 02, 2009 8:01 am
It seems the choice of which way to cartop the AI depends on the characteristics of one's car - I can't slide my AI straight up onto saddles, like Stringy, because the rails on my Forester require the rear roofrack to be too far forward. On the other hand, I don't have a problem with the aka braces scratching the roof, like Pirate does - presumably the clearance of my racks is a bit higher.
PostPosted: Thu Jul 02, 2009 11:09 am
What I find interesting is that I've never seen any hobie kayaks in a store upside down, including the AI.
PostPosted: Thu Jul 02, 2009 5:33 pm
Chris my Thule roof racks are very adedequate to carry the AI inverted once up there. I like others here however found the AI is very unbalanced in the inverted position and impossible to get up there one up without risking significant damage to the car. I found that the only practical way I could carry the AI inverted on the roof racks was to put it up there right way up then flip it over. This involves an extra step when both loading and unloading and can be a bit of a hazardous process in high wind situations. Also far less salt water dumps onto the car if I carry it upright, almost nothing if I wipe the hull first with a towel before lifting it up unlike when inverted when it drips from all the nooks and crannies as well as the wet seat. I have read and viewed pictures here of several methods of loading and transporting the AI on the racks some quite elaborate and expensive but IMHO the system I am using is simple and cheap and fits the bill perfectly....Pirate :wink:
PostPosted: Thu Jul 02, 2009 6:38 pm
With my Thule Hullavator I can load the AI either way equally easy. But I normally carry it inverted because I often leave the AI on the cartop for extended periods and it needs to be locked - which is much easier inverted. I also have the illogical impression that it is more aerodynamic that way. The Hullavator cradles are padded, so I suspect that hull denting when carrying upright would likely be minimal - and would probably be the best way to carry it if I left the AKAs attached (but there is not enough room to leave the AMAs attached).
Click thumbnail to go to album.
