It is currently Mon Aug 03, 2026 9:38 am
 Post subject: Replacing Jib Cars
PostPosted: Mon Jul 06, 2009 4:36 pm
Just picked up a set of low profile jib cars to replace me ancient stock ones and I was wondering what the process is for removing the old ones. I'm guessing I have to drill out the rivets on the inboard end of the track and just do the switch and reinstall new rivets.
Question 2, what kind of rivet gun do I need to install SS rivets?
 Post subject: Re: Replacing Jib Cars
PostPosted: Mon Jul 06, 2009 5:31 pm
The inboard tarck end-cap is typically a screw fastener. If riveted... yes drill out to remove the cap to open the track. A basic rivit gun you can use on aluminum rivets is usable on a limited number of stainless rivets... with strong hands to work it.
PostPosted: Mon Jul 06, 2009 5:34 pm
Be careful when you drill out the rivets. They'll heat up and melt the plastic end cap.
Alternatively, you can take a couple of rivets out of the outboard end, gently slide a flat-bladed screwdriver under the track until it clears the corner casting. Slide old ones out and new ones in. Re-rivet and you're done.
You need a rivet gun that you won't find at your local hardware store.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=66422
$14.99 at Harbor Freight
PostPosted: Thu Jul 09, 2009 5:34 pm
Thanks guys
Users browsing this forum: Skipshot and 2 guests
