It is currently Fri Aug 14, 2026 6:29 pm
PostPosted: Mon Jul 06, 2009 9:44 am
Has anyone changed the main sheet to clew attachment method to something less pain inducing? Something like a knot?
PostPosted: Mon Jul 06, 2009 10:26 am
No,
but I once replaced the rope on the clew with a ball bungee,
but removed the ball after luffing for the first time while partially reefed...
ouch! :shock:
(I felt like one of the three stooges)
Kayaking Bob
P.S. I still use the bungee, but with no ball.
PostPosted: Mon Jul 06, 2009 2:03 pm
Actually, I added to it. The S hook came off one day while the sail was luffing. Being disabled, I had to flag down a friend for help. So, I crimped the S hook onto a large stainless carabiner that is clipped to the clew. I haven't been hit by it. Maybe it's heavier and doesn't flap around as much? Or, maybe I've just been lucky.
PostPosted: Tue Jul 07, 2009 10:52 am
How about a Harkin 226 dbl micro block tied on. Won't flail off when the sail luffs in a stiff breeze and has less mass to konk your noggin;)
Sarasota, Fl
s/v BonaFide
PostPosted: Wed Jul 08, 2009 6:00 am
Actually I was thinking about one of these:
http://www.harkenstore.com/uniface.urd/ ... Z56LC7CNTE
http://www.harkenstore.com/images/381.jpg
using a thin line about 1.5' long between the clew and the block.
PostPosted: Wed Jul 08, 2009 2:34 pm
Been there, have the lump but didn't find a solution!
Better to be a live donkey than a dead lion!
PostPosted: Wed Jul 08, 2009 7:06 pm
Actually this one weighs .5 oz, and it has everything I need to attach it to the sail, no metal required.
http://www.harkenstore.com/uniface.urd/ ... Z56LC47D1A
PostPosted: Thu Jul 09, 2009 7:42 am
apr67,
You're right. That small Harkin 351 carbo sngl block, or much smaller Ronstan 663 simply tied at the clew seems to be the best answer. I don't know what I was imagining with the dbl Micro. I had used a couple in another application on my big boat and got my overly creative brain cells mixed :roll: .
Thanks, Mike
Sarasota, Fl
s/v BonaFide
PostPosted: Thu Jul 09, 2009 8:19 am
I have tied several of those little carbo blocks to sails. Two of them are standard equipment on a Precision 185 jib. I would not want to fool with tying that little line every time I rigged my AI.
PostPosted: Thu Jul 09, 2009 12:07 pm
I would just pull the sheet through. I know it adds time, but man that darn block hurt. Perhaps its only an issue for newbies.
PostPosted: Sat Aug 22, 2009 6:39 am
You could try one of these:
PostPosted: Tue Aug 25, 2009 7:05 am
Or one of these....Pirate :mrgreen:
