It is currently Mon Aug 03, 2026 12:32 pm
PostPosted: Mon Jul 13, 2009 10:43 am
Has anyone put an H16 on their trailer backwards (and traveled w/ it) in order to use the Y bar on the trailer to give the mast that little extra lift in order to step the mast solo :?:
PostPosted: Mon Jul 13, 2009 10:55 am
Nope. I usually have no problem stepping the mast. It's a quick process for me. :D
-Eric
Eric
H16
Sail# 11500
PostPosted: Mon Jul 13, 2009 11:05 am
The only problem I ever have (while the boat is trailered) is the intitial lifting of the mast . Unless someone on the ground behind the boat raises the mast just a bit while I am on the tramp, it is almost impossible to get that thing lifted. So I was thinking if the boat was trailered in reverse and I used the Y bar as my little extra bit of lift I would be OK. My real concern is trailering the boat while it is placed backwards on the trailer.
PostPosted: Mon Jul 13, 2009 11:23 am
I made a tripod out of 3 aluminum tent poles that I use to hold the mast until I raise it. It could be long enough to give you that initial height you need. I tie a line to extend the length of the jib halyard and tie the other end to the bridle. I then raise the mast, lean into it, reach down to the jib halyard cleat, and pull the halyard tight and tie it off. Lowering the mast is just the reverse. I lower the mast onto the tripod after releasing the jib halyard.
Howard
PostPosted: Mon Jul 13, 2009 11:41 am
Howard,
I really appreciate the input and that is a great idea. I need a solution so when the family doesn't want to go or I can't find someone to come along I can still get out on the lake.
PostPosted: Wed Jul 29, 2009 3:18 pm
I had the same problem, finding help to step the mast, ordered a mast stepper#3142
from my local Hobie dealer ( a little spendy). One could fabicate a similar assembly.
The Rube Goldberg thing works GREAT!! it's easy on the boat, with the addition of some snap fasteners at the trap lines set up in less than 5 mins.
-Mike-
Sail# 43458
PostPosted: Sun Aug 09, 2009 7:05 pm
i rigged a pulley and tied it to the front of the trailer, I tie a line to the mainstay cable, as i step the mast holding the mast vertical i put the line and give it a few wraps around the mast and then insert the cotter pin works great.
