It is currently Sat Aug 08, 2026 11:30 pm
PostPosted: Thu Jul 14, 2005 8:32 am
I have a 2003 Getaway that I leave on the Beach. Do I ever have to be worried able leaving the corks out on the hulls to vent? I would like to keep in an screwed tight. With the way the transom is angled Ive been getting a little rain water in. Are there any vents in the hulls like the fiberglass 16s?. I tried to keep the deck ports in the cooler open, however the coolers are not watertight and don't want rain to get in the hulls. Great boat! Have had 3 fiberglass 16's before this one.
 Post subject: Vent
PostPosted: Thu Jul 14, 2005 1:00 pm
There are a number of places on the Getaway that should naturaly vent, so I don't think there is a problem leaving the plugs in.
 Post subject: email me
PostPosted: Thu Jul 14, 2005 3:11 pm
zhopper would you please email me your email address please. --Roy
PostPosted: Fri Jul 15, 2005 5:59 am
Great!
Thanks Matt
PostPosted: Mon Nov 06, 2006 7:45 pm
Matt, when I removed the plugs from my hulls this weekend, there was no water just a big "woosh" of air out of the port hull. I remembered this post from last year about the venting of the hulls. Where are the venting points that you mentioned? And is there any concern about pressure building up in the rotomolded hulls?
Thanks - oh, and the sailing was incredible this weekend.
David
 Post subject: Vent
PostPosted: Tue Nov 07, 2006 11:41 am
If you are concerned... (don't think this is an issue with a rotomolded boat / flex won't hurt the construction like a glass boat would) you could drill a very small hole in the 5" port lid, inside the cooler.
PostPosted: Wed Nov 08, 2006 9:06 am
Thanks Matt. I was more curious than concerned. What a great boat!
David
PostPosted: Tue Nov 14, 2006 12:02 pm
after keeping my plugs in for a few months noticed that condinsation was forming in the hulls. I live in Florida and the boat is on the beach, high humidity and heat. On sunny days its still a good idea to pull the lids and plugs to get the air moving around to dry out. I like keeping the plugs in all the time since rain water does get in and its hard to get the water out via the lids. My coolers always get a little water in them during sailing so i won't put any holes in the lid. Once water does get in the hulls it is hard since the drain plugs are a little higher thatn the bottom of the boat.
