It is currently Fri Mar 13, 2026 4:52 am
PostPosted: Mon Jul 25, 2005 7:59 pm
Several of the original batten pocket protectors have "popped" at least one rivet. I'm tired of waiting on parts via the mail, so instead of watching TV, here's my plan. :idea: I'm thinking of carefully drilling out all four rivets and installing brass hardware by heating the nuts and setting into the plastic.
Has anyone ever tried to salvage the originals? Any other thoughts or suggestions? :?:
Fleet 297
 Post subject: That works
PostPosted: Tue Jul 26, 2005 9:27 am
That's pretty much how I did it, but without heating anything. It worked like a charm.
In retrospect however, they are only light aluminum rivets and probably just as easy to drill and replace with another aluminum rivet if you have a rivet tool - which you probably do if you own a Hobie. If you don't have a rivet tool, any light duty rivet tool will work for this. (For most other work on the boat however you need a heavy duty tool that can set fairly long stainless rivets).
good luck- necessity is the mother of invention.
-Stephen
The fact that this windy world is largely covered in water obviously means that man was meant to sail.
PostPosted: Tue Jul 26, 2005 11:47 am
I replaced all of the batten pocket protectors on my jib and the main. The new protectors for the main utilize brass hardware with indentations that hold the nuts. As for the protectors for the jib, they have round holes (setup to receive rivets), but I opted to use brass hardware. I, like Stephen, did not heat the nuts...just used a little loctite on the screws. 3 years later, everything is still in place. If your plastic pocket protectors are not cracked, by all means I think that you can continue to use them with the new brass hardware.
Jeffrey
1983 - H14
1985 - H16
