It is currently Fri Jun 12, 2026 11:49 pm
PostPosted: Sat Jul 30, 2005 8:52 pm
Recently purchased a used 1986 H16. Looks like the mast head may have some cracks in it and could use replacing. I saw a reference on another post that the comp tip mast head will fit on my aluminum (non comp tip) mast. Is this correct? Is there still a seal that is needed like the old style mast head? Do I need to purchase anything other than the part 20614001 and some rivets?
Thanks in advance!
PostPosted: Sun Jul 31, 2005 4:59 pm
If the top of your mast is not currently sealed then I'd take the opportunity to seal it. Heck, I might re-seal it just to be safe. Other than that, I think you should be okay with your old stuff but I haven't made this switch so I can't say for sure. :)
Warm regards,
Jim
PostPosted: Sun Jul 31, 2005 7:58 pm
So, aside from the seal, should the comp tip mast head fit on my all aluminum mast?
PostPosted: Sun Jul 31, 2005 9:28 pm
Authorized Hobie Dealer
Yes it fits fine, make sure you seal the new mast head on good.
Brad Stephens
www.sunjammers.com
Hobie Division 15 Chairman
Authorized Hobie/Vanguard/Hunter Dealer
Panama City Beach, FL
PostPosted: Mon Aug 01, 2005 3:53 am
Much obliged for your help!
Thanks!
 Post subject: CompTip mast head
PostPosted: Mon Aug 01, 2005 3:39 pm
CompTip mast head also requires the CompTip halyard.
PostPosted: Mon Aug 01, 2005 8:07 pm
In order to do this repair myself, I will need to aquire a rivet gun. Anyone have some recomendations (best bang for the buck)? Also I saw a post on another topic mention using casings with the rivets? Can someone please help me with this?...
Thanks!
