It is currently Thu Jun 11, 2026 8:27 am
 Post subject: epos
PostPosted: Mon Aug 01, 2005 5:26 pm
is there any information on the pros and cons for each type of epo?
there must be other differences, otherwise why make three? any feedback?
PostPosted: Tue Aug 02, 2005 7:43 am
Basically, the white blades make it easy to see kelp or weeds on the blade and they are less expensive.
The carbon / carbon-kevlar ones are lighter and stiffer (and look cooler). However, they must be protected from the sun (they will bubble from the heat).
 Post subject: Bubbles...
PostPosted: Tue Aug 02, 2005 9:30 am
Bubbles... are an effect of bad core material too. We have addressed that by changing the core.
PostPosted: Sun Aug 07, 2005 10:43 am
I have a set of the carbon EPO s. I noticed a few bumps on the surface. You can see them if you looks at the blade at a angle and can feel them when rubbing your hand across the blade. Is that what you mean by bubbles? I aways keep them covered.
Just looked at them again definately just minor surface imperfections. They are so shiny and black everything shows up.
PostPosted: Sun Dec 17, 2006 11:04 pm
Sorry to bring up an old post, but is the bubbling that happens in the core protected by warrantee?
 Post subject: Warranty
PostPosted: Mon Dec 18, 2006 3:06 pm
Yes,
Warranty on parts is 1 year and would cover delamination / bubbles.
