It is currently Thu Aug 20, 2026 9:14 pm
PostPosted: Thu Sep 17, 2009 8:02 pm
I still keep mine in a sandwich bag after Chekika's and Jim_L's horror stories about corroded battery compartments. Never heard of dielectric grease - sounds promising. Bob, you say you filled the USB compartment with the grease. That didn't interfere with the contact when you inserted the USB plug? Do you use it in the battery compartment?
PostPosted: Thu Sep 17, 2009 9:22 pm
Thanks for the tip Bob - I'll keep it in mind. However when I have the dodger on and mount it in suspended from the upper edge in front of me, it should be OK.
I'm sure there will be many other times whee I will use the RAM mounting in the cup holder - in which case I had better apply dielectric grease. 8)
Mickey
2016 AI Hibiscus
PostPosted: Fri Sep 18, 2009 9:59 am
That's the nice thing about dielectric grease, it doesn't interfere with electric connections, but protectes them from corrosion. I just wipe off any grease on the cable end after use and add a little back on the GPS USB socket before closing. I haven't put any on the battery terminals yet.
I'm surprised on how well the the batteries last. I'm only on my second set of AA's. I've never has a major moisture problem with the battery contacts in boating electronics, but I learned never to try to change batteries on or near the water. Too much moisture always got trapped in.
I keep most of my other electronics in waterproof bags, even if it's waterproof (marine radio) but more for quick cleanup. With the GPS, I haven't found a bag that will let me use it in the RAM holder.
It does seem that the salt and moisture get to everything, sooner or later though. :?
PostPosted: Fri Sep 18, 2009 1:44 pm
Thanks for the info Bob. BTW here's the bag I use: viewtopic.php?f=71&t=11967&p=65816.
PostPosted: Fri Sep 18, 2009 3:13 pm
:lol: I think I can fit it in my budget.
Thanks for the laugh Chris.
