It is currently Mon Aug 03, 2026 10:34 pm
 Post subject: Outback Warranty?
PostPosted: Thu Aug 11, 2005 4:28 pm
Will my warranty be void if I drill into the yak to mount rod holders? I have a fish finder and 2 rod holders that I would like to mount (rod holders in the back and fishfinder just infront of the front left built in rod holder) All this talk on the forums about leaking hulls, I want to know for sure if mine will be covered if it does indeed crack. I wouldnt think it would matter as everything that comes standard mounted on the surface of the yak is screwed on.
 Post subject: Warranty
PostPosted: Sat Aug 13, 2005 9:00 am
Your warranty will not be void related to mounting accessories. Unless... you mount something and it causes a failure directly related to the installation or use of that accessory. That would be quite obvious.
