It is currently Wed Aug 05, 2026 4:02 am
PostPosted: Mon Oct 05, 2009 5:15 pm
The cord attaching my Bow carry handle has frayed.
Can you replace the cord on the handle (in other words, can you open up the handle and easily put it back together?)or do you need to order an entirely new handle?
PostPosted: Mon Oct 05, 2009 9:17 pm
I think the current handles are molded and cannot be reused. Hobie used to use a hollow PVC handle though that was re-cordable. You can make one with 1/2" schedule 80 (for gray) or schedule 40 (for white).
--Trim your PVC to length (about 4")
--Round off the edges with a file or sandpaper
--Drill a hole in the middle just large enough for your new lines to pass through
--Pull the lines through and tie the ends together in with a simple knot
--Stuff the knot back in the tube
Below left is a pic of our first Hobie tandem with original handle -- worked great! On right is a similar "T" handle that was easily made to haul a ballast tube.
Image Image
Or you can buy a new molded handle for about $10. 8)
PostPosted: Tue Oct 06, 2009 12:07 pm
Thanks Roadrunner.
It didn't look like the Hobie handle could be taken apart to replace the cord but I have been able to do that with my old Ocean Kayak so I thought I would ask here first.
The Hobie handle is so nice it seems a shame to throw it away (or buy a whole new one) simply because of frayed cord but oh well...
PostPosted: Tue Oct 06, 2009 1:24 pm
It looks like mine might come apart. There are two holes underneath. I would try to take it apart if the line was broken. Try hammering two dowels or punches into the holes and see if the top pops out. A second choice would be to drill about a 1/2 inch hole in the top till you got to the string. Then remove the string insert a new one and tie a knot which would slip back into the hole. Nothing lost by trying.
I'm right 98% of the time. The other 3% I don't worry about.
PostPosted: Tue Oct 06, 2009 4:14 pm
You can not disassemble them. The line pass through a small stainless fitting that is molded into the handle.
76050001 HANDLE KAYAK (MOLDED) $10.00 each
