It is currently Wed Aug 05, 2026 4:21 am
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2, 3  Next
PostPosted: Thu Oct 22, 2009 4:09 pm
[*]This information is being released today on our website. This has already been shown in our kayak models brochure and in the accessories catalog that is mailing this week.
http://www.hobiecat.com/kayaking/accessory_details/accessory_evolve.html
Price (USA) $1,899.00
PostPosted: Fri Oct 23, 2009 12:39 pm
would like some more specifics on this. like how long will it run at top speed? and how fast? is the throttle completely adjustable from low to high or is it 2 speeds low and high?
PostPosted: Fri Oct 23, 2009 2:30 pm
Up to 8 hours at a cruising speed of 2 knots. I think this drops to about an hour at full throttle. My boy was jetting around for about 2 1/2 hours without completely emptying the battery.
The throttle is completely adjustable in forward and reverse.
PostPosted: Fri Oct 23, 2009 3:40 pm
This past year I was looking into purchasing a Torqeedo electric drive for a small flat bottom boat, what I was told about the Torqeedo it has high noise level. Can you mention what the decibel level is on evolve unit?
PostPosted: Fri Oct 23, 2009 3:52 pm
I wouldn't describe it has a high level of noise. There is a low level humm / whine that is not present with a standard trolling motor. That is due to the gearing system. The gearing is how the motor gets its power and effeciency.
If you were to troll... the pedals are quieter. We imagine using the motor to get places and use the pedals in stealth quiet mode.
PostPosted: Fri Oct 30, 2009 5:15 pm
Except if you have a PA ... because the Evolve doesn't fit on the PA and still allow use of the pedals now does it ? :roll:
PostPosted: Fri Oct 30, 2009 8:23 pm
You're absolutely right. You would have to pull the electric motor and put the Mirage Drive in. Start to finish in a minute or so depending on where the unused propulsion unit is stowed.
Four easy steps: 1) insert the prop alignment rod; 2) unplug; 3) lift the 7 lb. motor; 4) drop in the 7 lb. Mirage Drive. Start to finish, wouldn't it be nice if you could rig your fishing gear that fast? :wink:
Or, if you like to sail (or motor-sail), you could just shut off the motor and troll with your sail under the right conditions. The motor would be immediately available if needed. 8)
PostPosted: Wed Nov 04, 2009 6:54 pm
does the motor pivot out of the way when a boulder or other obstruction is encountered while mounted in the drive well like in a PA?
PostPosted: Wed Nov 04, 2009 9:42 pm
Not that I'm aware of -- it looks like a pretty solid set-up. There is no room to retract or swing without the prop striking the hull and I didn't see or read about any sheer pin in the system. I believe the prop relies on the skeg for protection.
I understand Hobie rammed a few things with it while testing to make sure the skeg wouldn't buckle, etc. All the same I imagine there are limits beyond which there could be damage. 8)
Incidentally, the prop alignment tool (shown here) is only briefly inserted after the motor has stopped when pulling the motor out.
PostPosted: Thu Nov 05, 2009 11:44 am
The drive well mounted system does not "kick up".
Not visible in the photo, within the black foil shaped shroud, is a thick fiberglass "batten" that the motor mounts to. This gives some impact protection to the MirageDrive well mounted system.
This was tested with many full speed beachings on a concrete ramp. At one point this even left the boat suspended on the grounded motor. Pretty tough. The bottom keel is also replaceable if it gets damaged.
PostPosted: Fri Nov 06, 2009 12:37 am
are there plans to have a kit that connects to the rear end of a pro angler
PostPosted: Fri Nov 06, 2009 6:02 am
Trying to figure out how to carry 6, 8D batteries. Should be able to get up on plane. Or maybe a weed wacker motor hookup. Or if I get a smaller kayak to trailer behind my Adventure I could carry my generator and run a extension cord.
I'm right 98% of the time. The other 3% I don't worry about.
PostPosted: Fri Nov 06, 2009 9:44 am
can you bluetooth electric yet :?:
PostPosted: Fri Nov 06, 2009 11:54 am
That is on the "to do" list.
PostPosted: Sat Nov 07, 2009 2:49 am
hurry up maaaaaaan i got a pro angler coming to my local store and i reckon i will be purchasing. cant decide on ivory or yellow
