It is currently Fri Jun 19, 2026 1:25 am
PostPosted: Sun Nov 22, 2009 5:09 pm
All,
My jib sheet keeps getting pinched by my mast when I tack. Matt Miller told me a solution with a bungee chord that was made standard gear on 18's, but I forgot! (sorry Matt!) :mrgreen: I just got six feet of new bungee to play with so what do I do again?!? Thanks All (especially Matt M.) Take care and have a Hobie day!!!
Sean Wheeler
http://hobie-14.ning.com/profile/SeanWheeler
'83 Hobie 14 Turbo "Rio"
Blue Hawaii Sail #40954
PostPosted: Sun Nov 22, 2009 6:30 pm
It works nicely because you can do / undo the shock cord from the mast without untying it.
Obviously, this only works if you've got the newer-style jib halyard block on the front of the mast. Otherwise, you'll need to put a fairlead or a hook there.
PostPosted: Sun Nov 22, 2009 6:46 pm
Matt,
Will that work on the 14 Turbo? Could I go through the Main halyard cleat then to the striker?
Sean Wheeler
PostPosted: Sun Nov 22, 2009 6:59 pm
Cleat might be a little high, but it's worth a shot.
PostPosted: Sun Nov 22, 2009 7:05 pm
Thanks Matt!!! You're the man! :mrgreen: Take care.
Sean Wheeler
PostPosted: Mon Nov 23, 2009 8:36 am
rsbw wrote:
All,
Never had a problem with jib sheet,but it appears Mick Butler (Hobie 16 World Champion) uses the same setup.
