It is currently Mon Aug 03, 2026 5:59 pm
PostPosted: Tue Nov 10, 2009 5:42 pm
I have a 1987 H-16 that I sail fairly hard. I am beginning to have problem with the left pontoon. The posts (front and back) appear to be pushimg down through the bottom of the hull. A crack has appeared (approx 6" long) where I assume the base of the post fits into the bottom of the pontoon. The top of the pontoon appears to be deflected downward as well. The crack associated with the forward post has started to leak. Is this a common problem with H-16s, and is there a standard fix? Thanks in advance for any help.
PostPosted: Thu Nov 12, 2009 9:06 am
Sounds like the beginning of structural failure of the deck and pylons. Any attempt to repair may not be permanent or safe.
PostPosted: Sun Nov 29, 2009 9:30 pm
Grrrrrrrrr.. It's a HULL, not a PONTOON.....
:evil:
PostPosted: Mon Nov 30, 2009 7:11 am
Check out the "Pylon Shoe Repairs" article in the Sept/Oct 2009 HOTLINE magazine.
http://www.hobiecat.com/hobieclass
cron
