It is currently Sat Feb 07, 2026 2:55 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 12 posts ]
 Post subject: Matt - Rudder Question
PostPosted: Mon Nov 16, 2009 8:50 am
Matt,
With the new can coming out soon, it would be very helpful if Hobie could provide detailed steps on proper installation and adjustment. Yesterday, my son and I finally got to make our maiden voyage in the Pro Anglers. (Work has been killer). After 3 hours both boats would make a hard turn right or left without touching the rudder and both rudders have a good inch to two inches of slack in the control stick.
Now, I know I need to tighten the strings to get rid of the slack, but how tight? and what about the boat turning unexpectedly?
The only thing I have issue with this boat is the rudder and I can live with that, given I have a easy adjustment procedure.
As I go through the posts on rudder adjustment, there is no do this first then do that.
Lastly, when can we expect the new large can?
THANKS!!!
PostPosted: Mon Nov 16, 2009 10:42 am
The new drum is here. We will be contacting owners shortly, but you can order the free ones for your boats from your dealer now.
There is a knob under the steering handle for line tension adjustments (manual / Page 6). Spin either way till snug. The tension needs adjustment due to shrinkage and expansion of the system due to temperature. Its simple and quick to adjust to your liking.
PostPosted: Mon Nov 16, 2009 10:58 am
Thanks!!
PostPosted: Mon Nov 16, 2009 9:44 pm
I just got an email from my dealer that they are closing. how will I get the replacement drum for my PA?
PostPosted: Tue Nov 17, 2009 4:26 pm
From the next closest dealer... or if you have already done your warranty registration with us... we will be mailing direct. Worst case, you can get it direct from us by supplying your details.
PostPosted: Wed Nov 18, 2009 2:21 am
whats a drum for, i just got my Pa in the Uk. Will i need this and why?
PostPosted: Wed Nov 18, 2009 4:13 am
It's a larger drum for the rear portion of the rudder system that will effect the turning radius for the kayak. It'll make the tracking a little easier I'm understanding. I'm hoping. What I've noticed in mine is in straight line pedaling, it wanders a little. Takes some steering corrections to keep going straight and seemingly a little more than you'd think necessary. But on the other hand, in regular paddling you correct on every few strokes so it's not much different.
Yakkingaway
Portsmouth, VA
PostPosted: Wed Nov 18, 2009 6:19 am
I look forward to the new drum.
But I think when you adjust with a paddle it is second nature to your paddling stroke. With a rudder it requires a specific action to adjust. I have read accounts where PA owners get used to the small drum and are not required to make the constant adjustments. I believe that with the PA rudder positioned where it is it makes the boat handle like a much smaller boat. I do like the way the rudder is protected under the boat and being able to turn within its length. There you have it, trade offs all around.
PostPosted: Tue Dec 01, 2009 8:49 am
i live in the uk and have a p.a. will the drum be sent to me or will i have to get it from the dealer?
i have registerd the boat with hobie
PostPosted: Tue Dec 01, 2009 4:12 pm
Hobie Team Member
I am one who spent enough time to pretty much get used to the rudder and didn't have to touch it much more often than I do on my Revolution. But, I plan on installing the new drum to see if that is what I want, knowing I can always go back to the original.
I hope the shop gets the new drum before the ice gets here which is any time now. If that happens, it will be the end of April until I will get to try it unless I do some southerly migration :lol:
Roger
http://www.aldenofsunapee.com/
Image http://www.NEKF.com/
PostPosted: Tue Dec 01, 2009 5:19 pm
We only shipped drums direct to North American owners. You need to request this from your UK dealer.
PostPosted: Tue Dec 01, 2009 5:21 pm
FYI... rudder drum details are here: http://www.hobiecat.com/community/viewtopic.php?f=78&t=16432 "Pro angler steering"
Too many threads on the same topic. I am going to lock this one.
