It is currently Sat Jun 20, 2026 12:00 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Wed Dec 16, 2009 2:52 pm
jmecky wrote:
I did try to use enamel spray paint but it could not cover the pin holes and left a dimple on every pin hole
I found that out the hard way! I put three coats of epoxy paint on some old sun-baked EPO's and they still look like hammered hell.
Sheet In...Max Out
www.fleet297.org
PostPosted: Wed Dec 16, 2009 3:28 pm
Now I'm screwed, look at this and tell me what went wrong, and what should I do to fix it.
I used High Bond white gel coat with wax, 2 oz styrene per pint of gel coat to thin, 4 cc of hardener, 1 tube of black pigment for gel coat. it 72 out side and sunny
Sail # 10505 or 277
Image Image
PostPosted: Wed Dec 16, 2009 8:55 pm
What you did wrong? - No surface prep. At a very minimum, you needed to remove the sticker and wipe it all down with acetone.
You can't just shoot the stuff over a crappy surface and expect it to look good.
Clean it up with acetone, sand it smooth and start over.
PostPosted: Wed Dec 16, 2009 9:24 pm
I spend 3 hours sanding with a foam block first 150 then 220. Then I spend 30 min with 2 rags and acetone wiping the whole thing down, until all I saw was white when I wiped it with a white rag. Of course I did surface prep, who sprays gel coat with out prep. I left the sticker because there were layers of gel black epoxy on top of the stickers.
Sail # 10505 or 277
Image Image
PostPosted: Wed Dec 16, 2009 10:17 pm
Not to hijack:
Tom Machette wrote:
Its pretty standard that hobie have one of 3 diffrent types of rudders...
Lexan (White or Black plastic) - easily flexable
Fiberglass (also known as Racing rudders, White Knight rudders...) - Stiff and made like a boat foam core, fiberglass, and gel coat.
EPO's (black fiberglass impregnated/formed with black epoxy) - Very Stiff, not made by Hobie but by an affiliate of Colman CO. from when they owned Hobie.
Epo2's (Carbon/Kevlar, Carbon, White Fiberglass) - upgraded verson of the origional, they will have a sticker underneath the epoxy
Sorry to hijack,
I have some black ones that are very stiff but feel like plastic ( have to be the Lexan right? They are old I think), and some white ones that feel like they are fiberglass which I am assuming are the racing rudders.
Resume normal operation
Also, you cant use epoxy on polyester?
PostPosted: Thu Dec 17, 2009 1:21 am
Dang! I hate that! I feel a "Previous Owner" rant coming on, but I'm going to hold back :)
This is precisely why one should always use what the boat was made of to do the repair. I guarantee that some previous owner (PO) coated those suckers with a rattle can. Probably looked good for a couple of years for them. Then you come along and think all is right with the world and look what happened. That's a mess, but you'll get through it.
Here's what happened to me. I took on a group dagger board repair and had 12 Hobie 18 boards in the shop. 6 of them were coated with something other than gel and they did exactly what your boards did. 6 daggerboards!!! Done, do over! I called one of the owners to tell him that they would be another week due to a chemical reaction and he said, "Oh yeah, we coat them every year with spray paint." Dumb me for not catching it, but it'll never happen again.
Here's what to do: Hit em with acetone and a rag, get what you can. If some of the gel is stuck on well, hit it with some PVA and put them somewhere warm to kick solid. Then DA them with 80 grit and get past the coating, whatever it was. Don't be shy.
Then...
Fair the head where those casting scratches are with Formula 27, block with 80 G, Then block the whole thing with 120 and spray them with about 6 hot coats of gel.
PVA, wash, sand to 600 buff with 3m Perfectit 3 heavy cut.
Don't fret, they'll be beautiful!!
Look up my gelcoat video if you need some help. That's the right way to do it.
Last edited by Sail Revolution on Thu Dec 17, 2009 1:28 am, edited 1 time in total.
PostPosted: Thu Dec 17, 2009 1:26 am
And one more thing...
Since you're going through the trouble, mix some thickened resin and fill those holes and redrill them. Those are pretty worn. It will tighten up your rudder system alot.
Hope that helps. Happy sanding!
