It is currently Mon Aug 03, 2026 1:19 pm
 Post subject: Best sail cloth weight
PostPosted: Wed Mar 10, 2010 11:54 am
I am looking to purchase a new main for my 16 from a friend. The sail is new but a few years old and never used. It is made by Whirlwind sails. He does not know if the material is 4 or 5 oz and I don't know what the advantage would be for either. I mostly sail on protected waters and I do not plan on racing so that is not a issue. I do want a good sail and one that will last. I am on the East Coast and I really only use the boat 10 times a year in winds up to 15 knots or so, Although I do have the occasional capsize and heavier wind sailing days. Is there a easy way to tell what weight the material is and should I avoid it if its one or the other? Thanks
PostPosted: Wed Mar 10, 2010 2:30 pm
Chip at Whirlwind is a well respected sailmaker, and considering the amount and kind of sailing you do then your friend's sail will be just fine for you, regardless of cloth weight.
PostPosted: Wed Mar 10, 2010 5:08 pm
Because of the loads on cat sails (racing or not), heavier cloth is better.
PostPosted: Thu Mar 11, 2010 9:55 am
Whirlwind uses the lighter weight cloth for cost savings (they show 4 and 5 oz available... the 5 oz listed is nearly $200 more for a sail). Hobie Cat uses 5.6 oz.
