It is currently Fri Jun 19, 2026 6:51 pm
PostPosted: Mon Feb 16, 2009 9:59 am
Anyone out there know where I can find an old single sheave head for a Hobie 16? My top mast roller is shot and I'm desperately searching for one so I can sail again.
Thanks, Bill
PostPosted: Mon Feb 16, 2009 10:09 am
Maybe a dealer who cut off a mast to install a CompTip, but this has not been available for over a decade as a replacement part.
Worst case... install a CompTip mast head and use a CompTip type halyard.
PostPosted: Mon Feb 16, 2009 7:38 pm
I might have 1or 2 out in the yard! let me look when the snow melts!
PostPosted: Tue Feb 17, 2009 6:55 am
Check with Jeremy at Surf City Catamarans.I have the same problem and bought a used masthead from him.Waiting for spring to replace mine.
 Post subject: thanks
PostPosted: Tue Feb 17, 2009 8:46 am
that would be excellent. No big rush, but if and when you find one, please let me know and we'll do a deal. Regards.
PostPosted: Tue Feb 17, 2009 8:47 am
Thanks, I'll do that.
PostPosted: Wed Feb 18, 2009 7:47 am
Anyone know what the diameter is of that sheave and its center bore? Somewhere there ought to be a comparable replacement product. Sheaves aren't exactly rare in the maritime world.
PostPosted: Mon Mar 16, 2009 9:30 pm
I probabely still have one - not sure how good that one would be - typically the plastic pully is most of the time in bad shape due to age and UV light. If you can not locate a usable top, the pully could be fabricated out of a pice of delrin by using a router.
Thanks, Patrick
PostPosted: Tue Mar 17, 2009 7:28 am
Thanks, Patrick
Ed Louchard at Zephyrwerks said he would make me one from Delrin for $68 if I sent him an old one to pattern. I don't have a spare sheave to send him without taking my mast apart. Maybe if someone here has one we could get a group buy together.
http://www.zephyrwerks.com/
 Post subject: sheave
PostPosted: Wed Mar 18, 2009 7:02 pm
yoh wrote:
Thanks for the reply. That's a good idea/making one with a router. Any idea where I can find a pice of delrin? or if you fine a good one I'd be happy to buy it from you.
Bill
Thanks, Patrick
PostPosted: Sun Mar 22, 2009 5:44 pm
I got one out of the back yard it seems to be fine. It does have a nut and bolt holding the pully in place not sure what that is all about? But it seems to work fine.
I will ship it to you for $35
let me Know,
Andy Larson
PostPosted: Fri Jul 31, 2009 11:31 am
I dropped the mast, and it broke the wheel in the top. I actually found a person that would make the new wheel out of aluminum. It would cost around $70 and I could ship it anywhere in the us for around $6.00. Just let me know if you want me to have this guy make you one.
http://www.GetWetSailing.com It's A Great Day To Sail!
PostPosted: Sat Mar 13, 2010 9:37 pm
70 bucks sounds steep - at the same time if it is made from aluminum it will last for ever. The delrin version could be fabricated with "normal" household tools. Most of us should be able to drill a hole in a plate of delrin and cut a circle with a router bit. If you want to go fancy you could cut a couple of more holes to reduce weight...
PostPosted: Tue Mar 16, 2010 6:01 am
Bill did you get hold of that top mast roller. http://beachcatsaustralia.ning.com/
