It is currently Sat May 09, 2026 6:19 pm
 Post subject: Trailing a TI?
PostPosted: Mon Mar 22, 2010 12:24 pm
I will be trailering my TI whenever I finally get it but im not quite sure my trailer is long enough...
Matt what is the distance between the TI's cradles
and what is the distance between the TI's rear cradle and the tip of the bow.
Thank you
Sterling
2008 Papaya Adventure Island with Roller Furler Jib
Post about my jib
viewtopic.php?f=69&t=20991
 Post subject: Re: Trailing a TI?
PostPosted: Mon Mar 22, 2010 1:20 pm
Also Matt, any more information you can give us about the TI's new style cradles?
PostPosted: Mon Mar 22, 2010 1:46 pm
The forward and aft cradles (both molded as the same shape) are suggested to be spaced at 67" like the others, but they can vary a bit as the fit is not as tight as the AI.
PostPosted: Mon Mar 22, 2010 2:11 pm
With the cradles both for the AI & TI spaced 67" apart (good!), where does the extra 2 1/2' of the TI fall while trailered, compared to the AI? (fore vs aft)
Will an AI "sit" well on a TI cradle, or does it have to have it's own style cradle?
Thanks Matt for all your help.
PostPosted: Mon Mar 22, 2010 3:08 pm
The AI will not sit well on a TI cradle correctly. The TI's bow touches or nearly touches the hitch coupler and hangs off the aft of the trailer a little more.
PostPosted: Mon Mar 22, 2010 3:43 pm
Matt do you know how long the hobie trailer is?
thanks
Sterling
Post about my jib
PostPosted: Mon Mar 22, 2010 4:31 pm
About 15'
