It is currently Fri Jun 19, 2026 6:22 pm
PostPosted: Wed Nov 17, 2010 6:56 pm
Hey Guys! Been a while since I've posted. I've put a lot of miles and a lot of fish on my Revo over the past 6 months. One thing I've noticed, the Revo doesn't paddle worth a crap while the drive is in place - even with fins folded flat. If I take the drive out and use the cassete, the boat is much easier to paddle. I end up doing this more than I would like, because I like to fish shallow water in the marsh. SO that poses the question, where the hell do you put the thing while your're not using it but you're still on the water? Everywhere I've tried seems to get in the way. Really, about the only place it can go is in the tank well, then good luck putting anything else in there with it. I usually keep a 36 QT cooler in the tank well so I was thinking about trying to rig up a bungee system to somehow attach it to the cooler. I always keep it leashed, so I'm not worried about loosing it. Anyone have a creative storage Idea? Thanks!
PostPosted: Thu Nov 18, 2010 7:28 am
CrazyAl,
The mirage drive will fit easily in the front hatch of the Revolution with standard or ST fins. Turbo fins make the fit tighter but not impossible. With pedals toward the bow spread the fins slightly to go each side of the mast sleeve and you will get the drive in the hatch with a little maneuvering.
I have mounted back to back padeyes through bolted on each side of the mast sleeve for leashes. For a quick removal I stand the mirage drive pedals down and bungee it up against the mast/hatch with fins skyward. Insert the cassette which I have leashed inside the hatch for quick retrieval (parachute chord tied to a small brass eye screw that I I screwed into top of the cassette) then paddle till need the drive again.
You could also add padeyes so that you could bungee the drive atop the front hatch. Of course a leash on your drive at all times to prevent loss.
Revo
PostPosted: Thu Nov 18, 2010 9:05 pm
Hey thanks Revo. That's a good idea to stand the drive upright, never though of that. You have any pics of that?? Thanks again for the idea.
PostPosted: Sat Nov 20, 2010 1:27 pm
Can a Mirage be stored the same way in an Outback or Sport?
Revo_1756 wrote:
CrazyAl,
Revo
2009 Oasis
2012 Freedom Hawk Pathfinder
PostPosted: Mon Nov 22, 2010 10:28 am
CrazyAl,
I stand corrected. The Mirage drive will fit in the hatch of a Revolution with Regular or ST fins but not the Turbo fins if you have the cam lock system. The Cam screw posts keep the Turbo fins from going in far enough to fit the entire drive in the hatch. I do not know about the click & go system. If the click & go have a support that extends to the bottom of the hull most likely the Turbo fins will not fit in the hatch either. But there are alternatives as I mentioned.
You can set you mirage drive a few ways to be out of the way.
#1) standing the drive pedals down and bungee. The pedals fit nicely into the foot wells.
my back to back padeyes from inside hatch with cassette leashed. Swim Noodles for positive flotation.
#2) Lay pedals across hatch with fins vertical between legs works like a charm. I just did a 7 mile kayak tour and decided to paddle half the trip and this worked exceptionally well. I even forgot my bungee and it stayed put but I was on calm waters.
Hope the photos helped
Revo
PostPosted: Thu Dec 16, 2010 8:37 am
Dang Revo I thought I had missed something when I couldn't get my turbo's in the hatch, but didn't try real hard. Ok so they won't fit, oh well.
But your pic#2 is cool, will have to try that.
Paeddle on !
2010 Hobie Revolution 13 *sold
2010 Hobie Outback *sold
2015 Hobie Revolution 13 FOR SALE**********
One Ocean Storm cedar stripbuilt
2009 Native Ultimate 12
