It is currently Thu Jun 11, 2026 2:40 pm
PostPosted: Tue Aug 25, 2015 9:45 am
At about $900 and 125#, it looks like the lightest, cheapest game in town.
viz: http://portagepal.com/t2000.html
2017 Trailex 450 Trailer
Pre-September 2015 cradles
eMail: [email protected]
PostPosted: Tue Aug 25, 2015 10:37 am
I bought a Harbour Freight utility trailer and added 1 1/2' pvc bunks as runners. Also extended the tongue 3'. the cost on sale for the trailer was $250. it is currently on sale till the end of this month. I don't submerge the trailer, just drive it to the waters edge. The trailer you show can be submerged which is a plus, but I don't have trouble unloading and loading mine with someones help. If I were alone what you are considering would be best.
PostPosted: Tue Aug 25, 2015 10:59 am
SeaWorthy wrote:
I bought a Harbour Freight utility trailer and added 1 1/2' pvc bunks as runnners. Also extended the tongue 3'. the cost on sale for the trailer was $250. it is currently on sale till the end of this month. I don't submerge the trailer, just drive it to the waters edge. The trailer you show can be submerged which is a plus, but I don't have trouble unloading and loading mine with someones help. If I were alone what you are considering would be best.
I was considering the Harbor Freight option, especially after seeing FusionEng's elegant adaptation.
But then I started thinking about the severity of consequences if/when something like a bearing fails at expressway speed - and past experiences with low-end Chinese stuff.....I once had an eBike motor where they messed up cutting some axle threads....How in the world does somebody mess that up?
My only reservation about Portage Pal - and the reason for the post - is the narrow attachment point for the front bunk and the possibility of problems from twisting of the load.
PostPosted: Tue Aug 25, 2015 11:54 am
doesn't look like there is any form of suspension .. just a straight axle with no dampening ?
.. you hit a bump at highway speeds and the whole rig will be airborn for about 200' :o
Alan W.
.. and a Hobie Outback SUV
PostPosted: Tue Aug 25, 2015 12:37 pm
Coil springs. I couldn't see them either - but the web page makes reference.
PostPosted: Tue Aug 25, 2015 1:44 pm
My $.02 is that the boat sees more stress on the trailer while driving down the road than in the water.
Get the stiffest, best supporting trailer possible and the boat will last longer. Get the largest wheels and the bearings will last longer and run cooler.
PostPosted: Wed Aug 26, 2015 6:45 pm
Check out the Trailex....."all aluminum" , leaf springs, infinite adjustment of frame, axle assembly, cross braces. I've had 1 steel and 3 Trailex trailers. Steel trailer perhaps rode a little better, but the weight difference vs. aluminum is hugh.
Trailex also has several 'erector set' options easy to install and the price difference overall is not that much more.
All my trailers have had 8" wheels/tires and have been towed on interstates. The only tire ever lost was due to age, nothing else.
If height is important to you remember taller wheels raise the boat also.
fair winds,
bill
