It is currently Sat Aug 01, 2026 11:29 am
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
PostPosted: Thu Jun 11, 2015 11:54 am
http://www.thebeachcats.com/classifieds/catamaran-parts-for-sale/p14076-sail-box-cap.html
Zach
PostPosted: Wed Jan 13, 2016 9:18 am
I also have an Aqua Terra Toy Box without an end cap.
What is the Toy Box made of?
The lip on the open end (where the end cap fits) has become brittle and part of it has broken off. Is there any adhesive that will stick to this plastic?
Tim
84 H16
82 H16
87 H14T
Tortola Sails: 115222
Blue Prism Sails: 88863
Clearwater, FL
PostPosted: Wed Jan 13, 2016 9:20 am
Rotomolded Polyethylene. You can weld it. Very little sticks to it. Some epoxies adhere when surfaces are rough, but bonds are not great.
PostPosted: Wed Jan 13, 2016 9:27 am
Thanks Matt,
Do you think 5200 would work?
Tim
84 H16
82 H16
87 H14T
Clearwater, FL
PostPosted: Wed Jan 13, 2016 9:33 am
5200 is mosty a sealant. Not really adhesive. G/Flex Epoxy maybe.
PostPosted: Sun Jan 17, 2016 3:58 pm
I have fixed my plastic toy box withe the G Flex epoxy and it has held up well. I fixed broken and cracked flanges about 4 or 5 years ago. Still holding up well.
1987 Hobie Holder 20 #273
dale.vanlopik"at"att"dot"net
PostPosted: Tue Mar 15, 2016 7:12 pm
Location: Grand Haven, Michigan and Kitchener, Ontario Canada
I too have an Aquaterra toy box that is missing the end cap. Is there any way I could get one from anywhere?
A wise man once told me "God does not subtract from mans allotted time the hours spent in sailing"
'88 H16 Sail #91037
PostPosted: Sun Jan 29, 2017 8:33 am
Here's how I dealt with the back cap latch/security and leaking lid issues.
Removed and junked the original cap latches as they were worthless. Replaced them with hardware store hasps.
https://drive.google.com/file/d/0B6l8KN ... sp=sharing
To keep the cap from rattling around I installed kayak hooks and bungees similar to the current Hobie design.
To eliminate leaks at the front lid I got a 55 gallon plastic drum and made a MAGNUM lid, then secured it with bungees.
I used this product (Home Depot or Lowes) to make a gasket/seal at the back end, inside, about an inch in from the edge (not visible in the photo)
I've been using the toybox in this configuration now for more than a year with zero leaks or security issues.
Hobie 16 (3 formerly)
MacGregor 25 (formerly)
Chrysler Dagger 14 (formerly)
NACRA 5.0 (currently)
High Point, NC
PostPosted: Tue Feb 14, 2017 3:26 pm
I made a fairly simple rear lid for mine out of plywood and bungy it on, similar to above,
also have a leash for it. Must be painted and/or epoxied to seal edges.. mine has held up
for a while now..doug
