It is currently Wed Aug 12, 2026 12:54 am
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: Hobie Cart confusion
PostPosted: Fri Jun 26, 2015 6:26 am
I just ordered a 2015 PA14(my 1st Kayak)from ACK, can't wait to get it, but I also ordered the Hobie Heavy Duty Plug in Kayak Cart. Where exactly do the cracks/breaks occur so I can detect them hopefully b4 the warranty runs out :?:
PostPosted: Fri Jun 26, 2015 6:33 am
I guess I'm lucky as I own 2 of the Heavy Duty carts with the large black tires and have experienced zero issues. But I don't use them to pull a loaded PA long distances.
I did add a small section of PVC on each shaft under the black collars to ensure the tire clearance was never an issue. The collars never seemed to hold right and always slipped down on the metal shafts. :D
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Pro Staff
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Mon Jun 29, 2015 7:31 pm
Matt, here's a link to the Youtube of the Australian cart (trolley) by David Laird to which I was referring:
https://www.youtube.com/watch?v=U17gvh5xXrg
PostPosted: Mon Jun 29, 2015 8:13 pm
Ranger:
I doubt highly that any new carts in anyones inventory are the old defective frames. That problem was cleared up a couple years ago. The older frames with the potentially weak welds are easy to spot, they have a small mig weld spot attaching the frame to the axle usually just in one or two spots. The newer inproved frames are tig welded all the way around each axle (really obvious). Even the older frames with the spot mig welds are highly unlikely to break except under extreme load.
Hope this helps
FE
PostPosted: Tue Jun 30, 2015 11:34 am
Nice! That is some very custom work there.
PostPosted: Tue Mar 22, 2016 1:31 am
I I've been on the YouTube channel of David Laird and no reference to how to buy or order one of these awesome trolleys. I want to order one when I get my TI. Any reference to where I can obtain one for myself?
PostPosted: Fri Apr 29, 2016 9:44 am
http://www.ebay.com.au/itm/201476117753 ... .l2649this
PostPosted: Mon May 02, 2016 4:14 am
I can attest to very high quality of the new cart. I bought "frame-only" option last year, as I already had the 30cm wheeleez. Top notch. Nice welds, solid (!) 1/2" stainless steel axle.
