It is currently Sat Aug 01, 2026 12:32 pm
 Post subject: Early EPO rudders
PostPosted: Thu Jun 23, 2016 4:37 pm
Picked up some early epo rudders #3847 for a 1985 hobie 14, they are too thick to fit in the rudder castings.
How much can I sand down the epo's? or am I out of luck and need to find another pair.
thanks.
Hobie Mark
 Post subject: Re: Early EPO rudders
PostPosted: Fri Jun 24, 2016 10:59 am
Not very much.
Better to spread the castings some (gently and gradually when they're warm - they are brittle) or find a newer set of castings.
PostPosted: Tue Jun 28, 2016 8:24 am
Grind off material in the castings... do not try to pry open. Castings don't bend easily... they crack. This was typical back in "the day".
PostPosted: Tue Jun 28, 2016 7:00 pm
Indeed. Filing is the preferred method. Bending is unpredictable and you won't know when you're reaching the limit - until the casting breaks.
