It is currently Sun Aug 02, 2026 1:47 pm
Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Sun Feb 11, 2007 2:22 pm
John Eaton,
Thanks for the input. That's where I've been putting them, I just wanted to be sure.
James
 Post subject: Get Album
PostPosted: Sun Feb 11, 2007 2:31 pm
James:
Get you a album here. Upload pics, then just copy and paste URL wherever you want to show pics, just like I did with minein above post, REAL easy:
http://www.thebeachcats.com/
Just click on the Catamaran Pictures link at left after you have done the free register. Also click on and join the Beachcars Yahoo groups link. It is an email based forum, BUT you get replys from all over the world.
Doug
PostPosted: Sun Feb 11, 2007 4:49 pm
I am going to buy this setup
http://www.harkenstore.com/uniface.urd/ ... Z56LC82NB6
http://www.harkenstore.com/uniface.urd/ ... MEB9Y99ZSW
Is this a good setup for my hobie (please be kind i'm a noob)
Cory
82 named SeaBass
 Post subject: Looks Great
PostPosted: Sun Feb 11, 2007 5:18 pm
Cory:
Those are the ones I have I think, BUT you may end up with 7 to 1. I see no place to start the first tie off too. May have to put a loop bracket on the top of bottom ratchet to start the reeving?
Doug
PostPosted: Sun Feb 11, 2007 5:23 pm
Cory,
Read what Brad with sunjammers posted. This is what comes on the new boats. And cheaper too.
H2640 upper
H194 lower
Fleet 297
 Post subject: 2.25"
PostPosted: Sun Feb 11, 2007 7:08 pm
I would get those from Hobie dealer. Just make sure you get 2.25' so you won't have any block to block problems, when you relly rake it back in heavy air. You will love the carbo's.
Good Lick,
Doug
 Post subject: Add pices like this
PostPosted: Sun Feb 11, 2007 10:55 pm
Post deleted. See post below.
PostPosted: Mon Feb 12, 2007 9:42 am
Authorized Hobie Dealer
this is over kill for a H16 6:1 is all you need. I will see if I can get a pic of my set up here in the next day or so.
Brad Stephens
http://www.sunjammers.com
www.facebook.com/sunjammers
PostPosted: Mon Feb 12, 2007 4:16 pm
this is what I am useing and seems to work great for me. Looks like I need to clean my blocks!
Brad Stephens
PostPosted: Mon Feb 12, 2007 5:10 pm
Misfit - Don't get that lower block! I did and regret it. Why? Adjusting the cam angle is a b!tch. First you must unscrew the side plates, but don't lose the itty bitty nut holding the two sides together, which means adjustments must be done over a table or floor or (keep your fingers crossed while doing it) tramp, because you don't want to lose that nut in the sand or grass or gravel. If you don't lose the nut, then you get to take off the side plates and rotate the cam to the spot you want, but make sure all 500 or so holes line up so you can put the side plates back on, and do this without losing the cam angle you want. Then you screw the whole thing back together. But if you're a set-it-and-forget-it sailor and you get it at a good price, then maybe this block will work for you.
If you get the lower block, as Hobie recommends, then cam angle adjustment is done by loosening the set screws and moving the cam to the angle you want, all while still attached to the boat and in seconds flat.
 Post subject: quick release
PostPosted: Mon Feb 12, 2007 5:19 pm
I am still curious if it is ok for me to be using the quick release shackle (refer to previous pic) on the upper block to connect to the boom bale or if it is elongating the system too much? It is convinient but I will sacrifice convinience for performance. It's difficult for me to make it out in the picture but it appears that you (Brad) are using a standard shackle with screw. Please forgive my terminology, I'm still learning all the names for the little stuff.
James
 Post subject: Wrong and don't worry
PostPosted: Mon Feb 12, 2007 6:39 pm
Brad:
I strongly disagree with your setup. Going outside and then underneath the bottom block is all wrong. :roll: :shock: It should twist the ratchet to the side and put bad loads on it, look at the picture I posted. This is & to 1, BUT look how smooth it flow. BELIVE me it makes a lot of difference when you try to dump the sheet at A mark to fall oof.
http://www.thebeachcats.com/modules.php ... _photo.php
James:
The quick release you have is fine, as long as you are not block to block when you sheet in. :wink: You should not be raked back that far. I had the old 3" block when I had 16 and had know problem. Did you ever measure your blocks to see if they were 2.25" or 3"? :?: Do you figure out the parts I said add? :?:
Doug
PostPosted: Mon Feb 12, 2007 6:50 pm
I like the way my blocks are run, they work for me. This boat was set up at Worlds and then again at Nationals, I think Greg Thomas sailed it in NY, I talked with him about the way the blocks are run as he likes it, I love it, allows for more mast rake and is a good conversation stater. I have not noticed it adding any pressure to the lower block while sailing.
Brad Stephens
PostPosted: Mon Feb 12, 2007 7:03 pm
What am I measuring to tell if my blocks are 3" or 2.25"? Do I measure the width of the blocks, or something else?
Thank you for showing me your setup. I think the 6:1 will work for me for the time being. I may have an extra block somewhere where I could try out the 7:1 setup. I'll have to wait for some warmer weather though, man I tell ya I'm getting ansy. If it means that I have to order a new block I may hold off, keep in mind I'm fresh out of college. I've got quite a list of things that I would like to purchase that are Hobie related, such as:
refiting hiking straps
a trap harness that actually fits
joining HCA
new lacing lines
new jib sheets
new carpet for side rails, the last set of carpet I got has deteriorated rather quickly, just a little over a year, even though the boat has been stored covered :?: I may go the neoprene route?.
probably new standing rigging too, I don't really know how old it is, at least over three years I would assume.
etc.
But I'm always willing to try new things, especially since I'm a newbie. I'll definately let you know what I think when I get the chance to try it on the water.
James
86' Redline Hobie 16
Sail # 76909
PostPosted: Mon Feb 12, 2007 7:07 pm
Sunjammers could you diagram the way you thread the blocks.
