It is currently Mon Jun 15, 2026 11:52 pm
 Post subject: Welding H16 frame
PostPosted: Sat Apr 21, 2007 7:33 pm
I have herd of epoxying the frames of older boats together for improved stiffness. What about Tig welding them together?
Evan
PostPosted: Sat Apr 21, 2007 8:43 pm
Only if you plan on never disassembling the boat.
PostPosted: Sat Apr 21, 2007 11:10 pm
Can you dissemble an epoxied boat?
1979 Hobie 16
PostPosted: Sun Apr 22, 2007 2:17 am
Sure. Heat up the joints with MAPP gas and separate with a mallet.
PostPosted: Sun Apr 22, 2007 8:02 am
Weld?
We had a guy in So Cal weld his 16. He did several short welds around the crossbars.
Good idea? He broke his crossbar. It weakened the crossbar extrusion and concentrated the stress at the welds. Bad combination.
PostPosted: Sun Apr 22, 2007 2:20 pm
So what we are really saying is that the frame has to be able to shift slightly, If that wasn't true then welding is no different than expoxying in that it should create a completely rigid structure, I do think the epoxy allows the frame some flexing in the joints otherwise it should break as well.
PostPosted: Sun Apr 22, 2007 3:29 pm
Welding leaves a heat affected zone around it, so if you don't do post-weld heat treatment it will actually make the metal around the weld weaker. I think that's what Matt is saying.
PostPosted: Sun Apr 22, 2007 8:59 pm
What is the best way to stiffen an older boat? Mine is a 79 and has quite a bit of play. I do not want to spend very much money it is just my weekend sailor not a racer.
Evan
1979 Hobie 16
PostPosted: Sun Apr 22, 2007 9:47 pm
Here is what the previous owner of my boat had done.
eyebolts instead of the regular hexhead then going diagonaly port rear to starboard front with a cable smaller then the stays and a turnbuckle and a second one from starboard rear to port front, this would also allow for squaring up the boat as well. I never though much of it, but what the heck, seemed to work.
Sam
PostPosted: Sun Apr 22, 2007 10:57 pm
Ew,
Tighten the tramp. Use low stretch line. That's the cheapest!
Sail Revolution
Join us on our new FB Page!
PostPosted: Mon Apr 23, 2007 9:06 am
On top of tightening the line add shims made of aluminum to the posts coming out of the hulls. I have found the best way to make the shims is to sit down and have a frosty beverage with a few friends while thinking about the job.
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
PostPosted: Mon Apr 23, 2007 4:12 pm
The only problem with frosty beverages is that I am only 17. I think that soda cans would work just as well.
1979 Hobie 16
PostPosted: Mon Apr 23, 2007 5:12 pm
Don't use Coke cans. That stuff will rot out anything. :lol:
PostPosted: Mon Apr 23, 2007 7:41 pm
Yeah, like you don't :roll: Who here wasn't 17 once?
PostPosted: Sun Apr 29, 2007 9:48 pm
Do older cats generally have a frame stiffness problem? I have a 73 that I have personally not sailed aggresively and would like to know if I should consider checking for this problem.
Being 18 i already know that soda cans will do no good... :P
charlie
'73 Hobie 16- orange and yellow
