It is currently Mon Aug 03, 2026 3:34 am
 Post subject: Sailing up wind
PostPosted: Wed May 23, 2007 5:45 pm
My Hobie 16 dose not seem to point very well. what could cause this?
Mast rake?
thanks,
Evan
1979 Hobie 16
PostPosted: Wed May 23, 2007 6:34 pm
Not enough mast rake or poor sail trim.
But "upwind" is relative. Are you trying to keep up upwind with other cats or monohulls?
Brian C
PostPosted: Wed May 23, 2007 8:14 pm
well i have instructed sailing on mono hulls for years. so mono hulls.
1979 Hobie 16
PostPosted: Thu May 24, 2007 9:10 am
Upwind your angle will not be as good as most monhulls, but your VMG will blow them away in all but the lightest breeze.
PostPosted: Thu May 24, 2007 9:51 am
Seems like the 14/16 was designed to punch through the surf, reach up and down the beach and fly hulls all the while :D
Sailing these boats upwind, and fast, is an art, experiment with mast rake and weight placement
Fleet 297
PostPosted: Thu May 24, 2007 3:27 pm
What srm and John said... Ease off the wind a bit and your cat will more than make up for lost angle with increased boat speed. I had a lot to re-learn when I changed from Mono to Multi (Thistle to H-17).
Brian C
PostPosted: Thu May 24, 2007 11:01 pm
thank you all for the advice
Evan
1979 Hobie 16
 Post subject: jib traveler
PostPosted: Sat May 26, 2007 7:32 am
Where should the jib traveler be set when going up wind?
John
 Post subject: Closest to the mast
PostPosted: Sat May 26, 2007 8:57 am
Generally towards the mast end of the track. In higher winds the car moves out a bit. The main traveler also can be moved out a bit as the wind speed rises.
