It is currently Fri Jun 19, 2026 12:48 am
 Post subject: Daggerboard marking
PostPosted: Fri May 02, 2008 9:26 am
How have forum members marked their daggerboards to indicate when the boards are raised enough when landing? I've thought about painting a line across the daggerboards to show where this spot is for easy reference and peace of mind. What other ways are there to do this?
PostPosted: Fri May 02, 2008 9:47 am
PostPosted: Fri May 02, 2008 10:40 am
Thanks, Matt. That's easier done than said.
PostPosted: Fri May 02, 2008 11:38 am
I mark mine for all the way up and for downwind sailing. Downwind they need to fill the well front to rear so all the way up is bad, and slow. I tape the deck and use a sharpie to mark them. It also keeps right and left boards right and left because the mark is on the inside only.
PostPosted: Fri May 02, 2008 1:06 pm
Is there/should there be a difference between right and left?
The ox is slow but the earth is patient
PostPosted: Fri May 02, 2008 1:46 pm
No, there shouldn't be a difference...it seems like boards get seated in the gasket material favoring one side or the other over time making them easier to raise and lower. In theory, the boards and trunks are identical.
Sheet In...Max Out
www.fleet297.org
PostPosted: Sat May 03, 2008 5:33 am
years ago, I started using 1/4" red automotive pinstripe tape to mark the daggerboards for the raised position and downhaul locations. Liked it better than markers because it was neater.
Chris
'88 H18SE Arís
PostPosted: Sat May 03, 2008 11:54 am
There's supposed to be 'gasket material'?!!!!! Seriously my wells are naked!
PostPosted: Sat May 03, 2008 8:40 pm
Thanks for the chance to exonerate myself :oops: I was thinking one thing and typed another.
Hobie 18 Rule 1.3 states "Anti-chafing and shimming pads may be added to the dagger board trunk to improve fit and reduce wear. ..."
Actually, full "gaskets" are illegal. Most use the Hobie shim kit or glue carpet pieces in the trunks to keep the boards stable.
Sheet In...Max Out
www.fleet297.org
PostPosted: Sun May 04, 2008 8:28 am
I've used paint pens available at hardware stores to paint a 1/4" strip on my daggers. Use the hull as a straight edge and drag pen across dagger while its in hull pocket.
PostPosted: Sun May 04, 2008 8:58 am
I know my boards are fully up when the top of the board is even with my trap handles. But that is different on each boat, you can find a reference point like that on your boat though.
 Post subject: Daggerboards
PostPosted: Sun May 04, 2008 8:43 pm
My daggerboards at this point only fit on a specific side ... this is because over the years of fixing the daggerboard wells and repairing the daggerboards each side is slightly different. Sailing/racing in NJ in the "bays w/ sandbars everwhere is tough on boards and wells ... you get REAL good at fixing them
You throw the boat together because you are behind schedule .... are late to the first start and have sailed downwind to the racing area .... go to put the "boards" down and they jam ... you find yourself yelling at the crew "swap the boards ... swap the boards ... hoping you can get them un-jammed quickly and swapped ... doesn't make for a good start!!!
So now I ALWAYS check to verify that my boards go up and down freely BEFORE I get ready to race
Been there ... done that.
Harry
HarryMurphey
H-18 mag/ #9458
Fleet 54 Div 11
PostPosted: Wed May 14, 2008 6:33 pm
I guess my colored electrical tape stripe is to low tech,red for starboard green for port.I should say stripes.
By the way when my boat is on the trailer I marked the downwind depth at about 6 in. sticking out of the well, just about where the dagger profile starts
to fill the well.Is this about right?
Shawn
82 h18 #8211
Div 3
PostPosted: Fri May 16, 2008 1:54 pm
that sounds about right Shawn
PostPosted: Fri May 16, 2008 6:17 pm
Thanx,shawn
