It is currently Fri Jun 19, 2026 9:48 am
 Post subject: Rudder question
PostPosted: Wed Oct 15, 2008 5:43 pm
What would be the purpose of the blue line located on the tiller arm?
PostPosted: Wed Oct 15, 2008 6:08 pm
Do you mean the rudder arm? The short piece of blue line? Best guess it's there to keep the rudder arm from moving to a 90 degree position to the hulls, which would allow an un-pinned rudder pin to fall out of the casting & gudgeon if the boat was to go turtle. Probably one of the best things you can do with rudder pins is to drill a very small hole thru it and insert a safety pin type of cotter pin to secure it to the transom of the boat. Where to drill the hole will depend on the type of gudgeons you have.
PostPosted: Thu Oct 16, 2008 11:09 am
Yes the rudder arm.
Maybe Jerome Le Gal has found some go fast secret :lol: .
PostPosted: Thu Oct 16, 2008 11:31 am
Bungee... not line.
Holds the rudder down (or up) a bit better in case the cam trips... rudder still stays down.
 Post subject: blue line
PostPosted: Thu Oct 16, 2008 12:10 pm
Is it just looped around the rudder adjustment bolt on the tiller arm and then around the pin on the bottom? It is hard to see in the picture.
PostPosted: Fri Oct 17, 2008 8:42 am
Yes.
PostPosted: Fri Oct 17, 2008 11:15 am
Good idea, I like it. :)
