It is currently Tue Jun 16, 2026 7:13 am
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri Mar 27, 2009 6:56 pm
:wink:
Frank, sailing '02 Getaway in Wichita KS. Lake Cheney
(Hobie 17 RIP, storm of '05)
PostPosted: Fri Mar 27, 2009 6:58 pm
What's the reason so many marinas have what's called "Wake Speed" posted on buoys. What the heck is "Wake Speed?" How fast does a small power boat need to go in order to make a wake?
PostPosted: Fri Mar 27, 2009 7:03 pm
What is a USCG type lV PFD? Describe what it might look like.
PostPosted: Fri Mar 27, 2009 7:09 pm
When entering a marina where there are breaking waves you have to deal with is it safer to speed up and try to out run the wave or to follow the broken wave in?
PostPosted: Fri Mar 27, 2009 7:11 pm
If a fiberglass & resin constructed boat catches on fire in your harbor, what is the main source of fuel for the fire?
PostPosted: Fri Mar 27, 2009 10:19 pm
Between a sailboat under sail power and a motor boat towing a skier, which has the right of way?
 Post subject: need everyone help
PostPosted: Sat Mar 28, 2009 5:23 am
Is the person who started this thread from North Dakota?
Bodhisatfa
PostPosted: Sun Mar 29, 2009 11:13 am
Rick Buchanan wrote:
yeah, you're right....got side tracked. Here goes Trigg- If a large powerboat with limited maneuverability is coming down a navigational channel inside a marina and you're on your Hobie 16 tacking left & right working your way out of the marina for a day sail who has to yield the right of way to avoid collision?
Ok, well normally, Sail has right of way over motor. Common sense, in this case could rule. If the power boat cna't maneuver and the Hobie can.... stay the heck out of the way
i.e. A freighter will not move out the way for a smaller vessel.
Division 10, Fleet 185
Hobie 17 and Hobie 14
PostPosted: Sun Mar 29, 2009 11:15 am
What is the visual distress signal requirement for a 20' power boat?
In CAN a boat over 19'8" must carry 6 flares, a water tight flashlight, a sound signalling device.
PostPosted: Sun Mar 29, 2009 11:17 am
Which boat needs to have a mechanical blower and what is the purpose of a blower? A) a power boat with a large outboard motor. B) a 15' power boat with an inboard motor. C) all sailboats over 20'
A blower is needed for any board motor boat. It is also required that the blower is run for atleast 4 mintues being starting the motor. The bloaer removes combustable fumes from the engine department.
PostPosted: Sun Mar 29, 2009 11:21 am
You are out on the Police boat at night and you see another boat crossing your bow in the near distance. The boat displays a red light which you can see. What are you supposed to do? If all you see from the other boat at night is a white light, which direction is the boat headed in relation to yours?
Red light. Port has right of way. Steer clear.
White light. Stern light. Assuming the boat is overtaking, must steer clear.
PostPosted: Sun Mar 29, 2009 11:24 am
Is a boat required to have an anchor on board?
Depends. 6m or less can have either an anchor or manual propelling device. Boats between 6m and 8m must have an anchor
PostPosted: Sun Mar 29, 2009 11:28 am
What does the phrase "Red right returning" mean?
Proceeding from seaward to upstream the red buoy must be on the right side
PostPosted: Sun Mar 29, 2009 11:29 am
Can a small fishing boat tie up to a nav aid to let out a fishing line?
Absolutely not.
PostPosted: Sun Mar 29, 2009 11:31 am
Wake speed can be posted for a number of reasons. Most commonly, wake in some area can cause serious environmental damage, wakes can cause damage to boats on docks etc. Different boats can create different wakes. It is the responsibility of the operator to monitor the wake.
