It is currently Fri Jun 19, 2026 6:37 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Re: Removing oxidation?
PostPosted: Thu Aug 27, 2009 7:50 pm
I did some 600 grit wet sanding then used 3M Super Duty rubbing compound (pep boys $21) with that cheap buffer from Harbor Freight on spot in the back of the hull that the oxidation was also bad to test results. Here is a after photo I forgot to take a before pic and I still need to buy some wax. http://www.flickr.com/photos/41605241@N02/3863204331/
Floyd
00 Tiger
http://www.HobieFleet33.com
10 Mile Surfside, Texas
Join us on our Facebook group: Surfside Sailing
PostPosted: Thu Aug 27, 2009 8:26 pm
it looks good in the picture.
Are YOU pleased with the result ?
If the grass is greener on the other side of the fence, maybe it is time to water your own lawn.
PostPosted: Thu Aug 27, 2009 9:03 pm
It's way better you can't see from that pic but there is a few very small spots that may need a little more sanding but I'm afraid to sand it too much. I hope the wax will make it shine like the rest of the boat. But I am very pleased it's worth the hard work what an amazing boat! Thanks for the tips everyone!
Floyd
00 Tiger
PostPosted: Fri Aug 28, 2009 8:53 am
It looks good. I cant wait to see what it looks like when its all done!
1992 Hobie Cat 18 #16943
PostPosted: Fri Aug 28, 2009 4:41 pm
One done and one to go! http://www.flickr.com/photos/41605241@N02/3866332614/
Lots of elbow grease but this side was bad!
Floyd
00 Tiger
PostPosted: Wed Sep 09, 2009 8:52 pm
Is there anything special that should be done to remove oxidation from the non-skid portions of the deck? I could see wetsanding being ineffective, but will rubbing compound and a power buffer get into the depressions?
PostPosted: Thu Sep 10, 2009 5:40 am
My boat was only lightly oxidized on the decks and non slip area but I did buff with compound and it did clean right up.
I took my boat out twice last weekend and now my non slip area on the deck already has some white looking film in it must be something from the water but I waxed this area real good so I was surprised to see it dirty already.
Floyd
00 Tiger
