It is currently Wed Aug 05, 2026 3:16 pm
PostPosted: Mon Mar 08, 2010 12:35 am
Does the Pro Angler need to be stored upside down like the other Hobie Kayaks or can it be stored right side up?
PostPosted: Mon Mar 08, 2010 8:24 am
With no authority, the suggested way to store them is upside down. If you take the precautions of spreading the pressure points out far enough and covering enough of the hull you could probably store them right side up. I'd take extreme care not to "cave in" your hull from improper pressure. They can be worked out. Just not something you want to happen. There are specific cradles for the PA.... that's what I'm going to use.
Yakkingaway
Portsmouth, VA
PostPosted: Mon Mar 08, 2010 3:28 pm
Works for me!
Get a set of cradles to store it on?
PostPosted: Tue Mar 09, 2010 3:50 am
So if I set up a trailer with the PA cradles I can leave a PA on there permanently without any issues?
PostPosted: Tue Mar 09, 2010 9:19 am
Yes, you can leave on a trailer with the cradles.
PostPosted: Tue Mar 09, 2010 11:11 pm
Ok, that's good news. :D
